Zigbee2mqtt device voice control with google home
I have google home and zigbee light bulb (aqara) connected to hassio,
I’m trying to voice control the light bulb but cant figure it out,
here’s my config in configuration.yaml:
google_assistant:
  project_id: Home Auto
  api_key: API-KEY
  exposed_domains:
    - vacuum
    - light
  entity_config:
    light.0x00158d000398e8ef_light:
      expose: true
      room: LIVING_ROOM
Thanks in advance!
Give the light a name
ok, gave it a name
how do I voice control it?
Does it show up in your Google Assistant/Google Home app?
no…any ideas why?
Did you configured the integration between Google Home and Home Assistant or are you using Nabu Casa?
Hi, I have configured the integration without the cloud…
And you see that app you created in the Google Assistant/Home app?
You then told Google to sync my devices?
Yes, I see “my test app” and I can control my vacuum but when a tell Google to sync it can’t find the aqara light bulb
Actually it says “something went wrong while syncing my test app”
So I found a solution for this, here is what I’ve done:
Unlink my test app in Google home app than told it to sync my devices, after re-linking the app the light bulb appears in the devices.
Thanks everyone for the help.
