Zigbee2mqtt device without values NAS-PD07
Hi there,
I bought a couple of NAS-PD07 from Aliexpress to connect to my zigbee2mqtt.
The device is supported by the bridge (link)
When I pair the device, the pairing ends without problem, here the log:
info  2022-12-10 17:48:26: Device '0xa4c138181993394f' joined
info  2022-12-10 17:48:26: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0xa4c138181993394f","ieee_address":"0xa4c138181993394f"},"type":"device_joined"}'
info  2022-12-10 17:48:26: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":{"friendly_name":"0xa4c138181993394f"},"type":"device_connected"}'
info  2022-12-10 17:48:26: Starting interview of '0xa4c138181993394f'
info  2022-12-10 17:48:26: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0xa4c138181993394f","ieee_address":"0xa4c138181993394f","status":"started"},"type":"device_interview"}'
info  2022-12-10 17:48:26: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"interview_started","meta":{"friendly_name":"0xa4c138181993394f"},"type":"pairing"}'
info  2022-12-10 17:48:26: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0xa4c138181993394f","ieee_address":"0xa4c138181993394f"},"type":"device_announce"}'
info  2022-12-10 17:48:26: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"announce","meta":{"friendly_name":"0xa4c138181993394f"},"type":"device_announced"}'
info  2022-12-10 17:48:27: MQTT publish: topic 'zigbee2mqtt/Sensor_T_CameraSingola', payload '{"battery":100,"humidity":52.79,"linkquality":120,"temperature":19.38,"voltage":3000}'
info  2022-12-10 17:48:35: Successfully interviewed '0xa4c138181993394f', device has successfully been paired
info  2022-12-10 17:48:35: Device '0xa4c138181993394f' is supported, identified as: Neo Motion, temperature & humidity sensor (NAS-PD07)
info  2022-12-10 17:48:36: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"definition":{"description":"Motion, temperature & humidity sensor","exposes":[{"access":1,"description":"Indicates whether the device detected occupancy","name":"occupancy","property":"occupancy","type":"binary","value_off":false,"value_on":true},{"access":1,"description":"Measured relative humidity","name":"humidity","property":"humidity","type":"numeric","unit":"%"},{"access":1,"description":"Measured temperature value","name":"temperature","property":"temperature","type":"numeric","unit":"°C"},{"access":1,"description":"Indicates whether the device is tampered","name":"tamper","property":"tamper","type":"binary","value_off":false,"value_on":true},{"access":1,"description":"Indicates if the battery of this device is almost empty","name":"battery_low","property":"battery_low","type":"binary","value_off":false,"value_on":true},{"access":1,"name":"power_type","property":"power_type","type":"enum","values":["battery_full","battery_high","battery_medium","battery_low","usb"]},{"access":1,"description":"Temperature/humidity alarm status","name":"alarm","property":"alarm","type":"enum","values":["over_temperature","over_humidity","below_min_temperature","below_min_humdity","off"]},{"access":3,"name":"temperature_min","property":"temperature_min","type":"numeric","unit":"°C","value_max":80,"value_min":-20},{"access":3,"name":"temperature_max","property":"temperature_max","type":"numeric","unit":"°C","value_max":80,"value_min":-20},{"access":3,"description":"Temperature scale (°F/°C)","name":"temperature_scale","property":"temperature_scale","type":"binary","value_off":"°F","value_on":"°C"},{"access":3,"name":"humidity_min","property":"humidity_min","type":"numeric","unit":"%","value_max":100,"value_min":1},{"access":3,"name":"humidity_max","property":"humidity_max","type":"numeric","unit":"%","value_max":100,"value_min":1},{"access":1,"description":"Link quality (signal strength)","name":"linkquality","property":"linkquality","type":"numeric","unit":"lqi","value_max":255,"value_min":0}],"model":"NAS-PD07","options":[{"access":2,"description":"Number of digits after decimal point for temperature, takes into effect on next report of device.","name":"temperature_precision","property":"temperature_precision","type":"numeric","value_max":3,"value_min":0},{"access":2,"description":"Calibrates the temperature value (absolute offset), takes into effect on next report of device.","name":"temperature_calibration","property":"temperature_calibration","type":"numeric"},{"access":2,"description":"Number of digits after decimal point for humidity, takes into effect on next report of device.","name":"humidity_precision","property":"humidity_precision","type":"numeric","value_max":3,"value_min":0},{"access":2,"description":"Calibrates the humidity value (absolute offset), takes into effect on next report of device.","name":"humidity_calibration","property":"humidity_calibration","type":"numeric"}],"supports_ota":false,"vendor":"Neo"},"friendly_name":"0xa4c138181993394f","ieee_address":"0xa4c138181993394f","status":"successful","supported":true},"type":"device_interview"}'
info  2022-12-10 17:48:36: Configuring '0xa4c138181993394f'
info  2022-12-10 17:48:36: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"interview_successful","meta":{"description":"Motion, temperature & humidity sensor","friendly_name":"0xa4c138181993394f","model":"NAS-PD07","supported":true,"vendor":"Neo"},"type":"pairing"}'
info  2022-12-10 17:48:36: MQTT publish: topic 'homeassistant/binary_sensor/0xa4c138181993394f/occupancy/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0xa4c138181993394f"],"manufacturer":"Neo","model":"Motion, temperature & humidity sensor (NAS-PD07)","name":"0xa4c138181993394f"},"device_class":"motion","json_attributes_topic":"zigbee2mqtt/0xa4c138181993394f","name":"0xa4c138181993394f occupancy","payload_off":false,"payload_on":true,"state_topic":"zigbee2mqtt/0xa4c138181993394f","unique_id":"0xa4c138181993394f_occupancy_zigbee2mqtt","value_template":"{{ value_json.occupancy }}"}'
info  2022-12-10 17:48:36: MQTT publish: topic 'homeassistant/sensor/0xa4c138181993394f/humidity/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0xa4c138181993394f"],"manufacturer":"Neo","model":"Motion, temperature & humidity sensor (NAS-PD07)","name":"0xa4c138181993394f"},"device_class":"humidity","enabled_by_default":true,"json_attributes_topic":"zigbee2mqtt/0xa4c138181993394f","name":"0xa4c138181993394f humidity","state_class":"measurement","state_topic":"zigbee2mqtt/0xa4c138181993394f","unique_id":"0xa4c138181993394f_humidity_zigbee2mqtt","unit_of_measurement":"%","value_template":"{{ value_json.humidity }}"}'
info  2022-12-10 17:48:36: MQTT publish: topic 'homeassistant/sensor/0xa4c138181993394f/temperature/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0xa4c138181993394f"],"manufacturer":"Neo","model":"Motion, temperature & humidity sensor (NAS-PD07)","name":"0xa4c138181993394f"},"device_class":"temperature","enabled_by_default":true,"json_attributes_topic":"zigbee2mqtt/0xa4c138181993394f","name":"0xa4c138181993394f temperature","state_class":"measurement","state_topic":"zigbee2mqtt/0xa4c138181993394f","unique_id":"0xa4c138181993394f_temperature_zigbee2mqtt","unit_of_measurement":"°C","value_template":"{{ value_json.temperature }}"}'
info  2022-12-10 17:48:36: MQTT publish: topic 'homeassistant/binary_sensor/0xa4c138181993394f/tamper/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0xa4c138181993394f"],"manufacturer":"Neo","model":"Motion, temperature & humidity sensor (NAS-PD07)","name":"0xa4c138181993394f"},"device_class":"tamper","json_attributes_topic":"zigbee2mqtt/0xa4c138181993394f","name":"0xa4c138181993394f tamper","payload_off":false,"payload_on":true,"state_topic":"zigbee2mqtt/0xa4c138181993394f","unique_id":"0xa4c138181993394f_tamper_zigbee2mqtt","value_template":"{{ value_json.tamper }}"}'
info  2022-12-10 17:48:36: MQTT publish: topic 'homeassistant/binary_sensor/0xa4c138181993394f/battery_low/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0xa4c138181993394f"],"manufacturer":"Neo","model":"Motion, temperature & humidity sensor (NAS-PD07)","name":"0xa4c138181993394f"},"device_class":"battery","entity_category":"diagnostic","json_attributes_topic":"zigbee2mqtt/0xa4c138181993394f","name":"0xa4c138181993394f battery low","payload_off":false,"payload_on":true,"state_topic":"zigbee2mqtt/0xa4c138181993394f","unique_id":"0xa4c138181993394f_battery_low_zigbee2mqtt","value_template":"{{ value_json.battery_low }}"}'
info  2022-12-10 17:48:36: MQTT publish: topic 'homeassistant/sensor/0xa4c138181993394f/power_type/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0xa4c138181993394f"],"manufacturer":"Neo","model":"Motion, temperature & humidity sensor (NAS-PD07)","name":"0xa4c138181993394f"},"enabled_by_default":true,"entity_category":"diagnostic","icon":"mdi:lightning-bolt-circle","json_attributes_topic":"zigbee2mqtt/0xa4c138181993394f","name":"0xa4c138181993394f power type","state_topic":"zigbee2mqtt/0xa4c138181993394f","unique_id":"0xa4c138181993394f_power_type_zigbee2mqtt","value_template":"{{ value_json.power_type }}"}'
info  2022-12-10 17:48:36: MQTT publish: topic 'homeassistant/sensor/0xa4c138181993394f/alarm/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0xa4c138181993394f"],"manufacturer":"Neo","model":"Motion, temperature & humidity sensor (NAS-PD07)","name":"0xa4c138181993394f"},"enabled_by_default":true,"json_attributes_topic":"zigbee2mqtt/0xa4c138181993394f","name":"0xa4c138181993394f alarm","state_topic":"zigbee2mqtt/0xa4c138181993394f","unique_id":"0xa4c138181993394f_alarm_zigbee2mqtt","value_template":"{{ value_json.alarm }}"}'
info  2022-12-10 17:48:36: MQTT publish: topic 'homeassistant/sensor/0xa4c138181993394f/temperature_min/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0xa4c138181993394f"],"manufacturer":"Neo","model":"Motion, temperature & humidity sensor (NAS-PD07)","name":"0xa4c138181993394f"},"enabled_by_default":false,"entity_category":"config","icon":"mdi:thermometer-minus","json_attributes_topic":"zigbee2mqtt/0xa4c138181993394f","name":"0xa4c138181993394f temperature min","state_topic":"zigbee2mqtt/0xa4c138181993394f","unique_id":"0xa4c138181993394f_temperature_min_zigbee2mqtt","unit_of_measurement":"°C","value_template":"{{ value_json.temperature_min }}"}'
info  2022-12-10 17:48:36: MQTT publish: topic 'homeassistant/number/0xa4c138181993394f/temperature_min/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"command_topic":"zigbee2mqtt/0xa4c138181993394f/set/temperature_min","device":{"identifiers":["zigbee2mqtt_0xa4c138181993394f"],"manufacturer":"Neo","model":"Motion, temperature & humidity sensor (NAS-PD07)","name":"0xa4c138181993394f"},"entity_category":"config","icon":"mdi:thermometer-minus","json_attributes_topic":"zigbee2mqtt/0xa4c138181993394f","max":80,"min":-20,"name":"0xa4c138181993394f temperature min","state_topic":"zigbee2mqtt/0xa4c138181993394f","unique_id":"0xa4c138181993394f_temperature_min_zigbee2mqtt","unit_of_measurement":"°C","value_template":"{{ value_json.temperature_min }}"}'
info  2022-12-10 17:48:36: MQTT publish: topic 'homeassistant/sensor/0xa4c138181993394f/temperature_max/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0xa4c138181993394f"],"manufacturer":"Neo","model":"Motion, temperature & humidity sensor (NAS-PD07)","name":"0xa4c138181993394f"},"enabled_by_default":false,"entity_category":"config","icon":"mdi:thermometer-plus","json_attributes_topic":"zigbee2mqtt/0xa4c138181993394f","name":"0xa4c138181993394f temperature max","state_topic":"zigbee2mqtt/0xa4c138181993394f","unique_id":"0xa4c138181993394f_temperature_max_zigbee2mqtt","unit_of_measurement":"°C","value_template":"{{ value_json.temperature_max }}"}'
info  2022-12-10 17:48:36: MQTT publish: topic 'homeassistant/number/0xa4c138181993394f/temperature_max/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"command_topic":"zigbee2mqtt/0xa4c138181993394f/set/temperature_max","device":{"identifiers":["zigbee2mqtt_0xa4c138181993394f"],"manufacturer":"Neo","model":"Motion, temperature & humidity sensor (NAS-PD07)","name":"0xa4c138181993394f"},"entity_category":"config","icon":"mdi:thermometer-plus","json_attributes_topic":"zigbee2mqtt/0xa4c138181993394f","max":80,"min":-20,"name":"0xa4c138181993394f temperature max","state_topic":"zigbee2mqtt/0xa4c138181993394f","unique_id":"0xa4c138181993394f_temperature_max_zigbee2mqtt","unit_of_measurement":"°C","value_template":"{{ value_json.temperature_max }}"}'
info  2022-12-10 17:48:36: MQTT publish: topic 'homeassistant/switch/0xa4c138181993394f/switch_temperature_scale/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"command_topic":"zigbee2mqtt/0xa4c138181993394f/set/temperature_scale","device":{"identifiers":["zigbee2mqtt_0xa4c138181993394f"],"manufacturer":"Neo","model":"Motion, temperature & humidity sensor (NAS-PD07)","name":"0xa4c138181993394f"},"entity_category":"config","icon":"mdi:temperature-celsius","json_attributes_topic":"zigbee2mqtt/0xa4c138181993394f","name":"0xa4c138181993394f temperature_scale","payload_off":"°F","payload_on":"°C","state_topic":"zigbee2mqtt/0xa4c138181993394f","unique_id":"0xa4c138181993394f_switch_temperature_scale_zigbee2mqtt","value_template":"{{ value_json.temperature_scale }}"}'
info  2022-12-10 17:48:36: MQTT publish: topic 'homeassistant/sensor/0xa4c138181993394f/humidity_min/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0xa4c138181993394f"],"manufacturer":"Neo","model":"Motion, temperature & humidity sensor (NAS-PD07)","name":"0xa4c138181993394f"},"enabled_by_default":false,"entity_category":"config","icon":"mdi:water-percent","json_attributes_topic":"zigbee2mqtt/0xa4c138181993394f","name":"0xa4c138181993394f humidity min","state_topic":"zigbee2mqtt/0xa4c138181993394f","unique_id":"0xa4c138181993394f_humidity_min_zigbee2mqtt","unit_of_measurement":"%","value_template":"{{ value_json.humidity_min }}"}'
info  2022-12-10 17:48:36: MQTT publish: topic 'homeassistant/number/0xa4c138181993394f/humidity_min/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"command_topic":"zigbee2mqtt/0xa4c138181993394f/set/humidity_min","device":{"identifiers":["zigbee2mqtt_0xa4c138181993394f"],"manufacturer":"Neo","model":"Motion, temperature & humidity sensor (NAS-PD07)","name":"0xa4c138181993394f"},"entity_category":"config","icon":"mdi:water-percent","json_attributes_topic":"zigbee2mqtt/0xa4c138181993394f","max":100,"min":1,"name":"0xa4c138181993394f humidity min","state_topic":"zigbee2mqtt/0xa4c138181993394f","unique_id":"0xa4c138181993394f_humidity_min_zigbee2mqtt","unit_of_measurement":"%","value_template":"{{ value_json.humidity_min }}"}'
info  2022-12-10 17:48:36: MQTT publish: topic 'homeassistant/sensor/0xa4c138181993394f/humidity_max/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0xa4c138181993394f"],"manufacturer":"Neo","model":"Motion, temperature & humidity sensor (NAS-PD07)","name":"0xa4c138181993394f"},"enabled_by_default":false,"entity_category":"config","icon":"mdi:water-percent","json_attributes_topic":"zigbee2mqtt/0xa4c138181993394f","name":"0xa4c138181993394f humidity max","state_topic":"zigbee2mqtt/0xa4c138181993394f","unique_id":"0xa4c138181993394f_humidity_max_zigbee2mqtt","unit_of_measurement":"%","value_template":"{{ value_json.humidity_max }}"}'
info  2022-12-10 17:48:36: MQTT publish: topic 'homeassistant/number/0xa4c138181993394f/humidity_max/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"command_topic":"zigbee2mqtt/0xa4c138181993394f/set/humidity_max","device":{"identifiers":["zigbee2mqtt_0xa4c138181993394f"],"manufacturer":"Neo","model":"Motion, temperature & humidity sensor (NAS-PD07)","name":"0xa4c138181993394f"},"entity_category":"config","icon":"mdi:water-percent","json_attributes_topic":"zigbee2mqtt/0xa4c138181993394f","max":100,"min":1,"name":"0xa4c138181993394f humidity max","state_topic":"zigbee2mqtt/0xa4c138181993394f","unique_id":"0xa4c138181993394f_humidity_max_zigbee2mqtt","unit_of_measurement":"%","value_template":"{{ value_json.humidity_max }}"}'
info  2022-12-10 17:48:36: MQTT publish: topic 'homeassistant/sensor/0xa4c138181993394f/linkquality/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0xa4c138181993394f"],"manufacturer":"Neo","model":"Motion, temperature & humidity sensor (NAS-PD07)","name":"0xa4c138181993394f"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:signal","json_attributes_topic":"zigbee2mqtt/0xa4c138181993394f","name":"0xa4c138181993394f linkquality","state_class":"measurement","state_topic":"zigbee2mqtt/0xa4c138181993394f","unique_id":"0xa4c138181993394f_linkquality_zigbee2mqtt","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}"}'
info  2022-12-10 17:48:36: Successfully configured '0xa4c138181993394f'
Unfortunately the device doesn’t show any value (battery, occupancy etc etc)…
Any idea on how to resolve this?
thank you
What does the device show if you got to the GUI and select it? (exposes tab)
Attached is an example Hue motion sensor.
here the screenshot
Hmm that’s weird. Maybe try a new battery, delete the device from z2m and try re-pairing it.
I do not think is a problem of battery or pairing, because both devices do the same ( I have two of them).
One more info: the device works fine with the Xiaomi Zibgbee Hub, so seems that is a Z2M miss-pairing
You could try raising an issue here GitHub - Koenkk/zigbee2mqtt: Zigbee 🐝 to MQTT bridge 🌉, get rid of your proprietary Zigbee bridges 🔨
Thank you fleskefjes, I did it :slight_smile: here… but i’m not so confident someone will answer.
