I am having big troubles trying to integrate Zigbee2MQTT with Home Assistant.
I have one RPi running the Zigbee2MQTT. This works fine and I can see all my devices there. I have enabled home assistant in the configuration yaml. This seems to work, since if I use MQTT Explorer, I can see that Zigbee2MQTT is sending out a discovery message for each device, which can be seen in the following image. I also have a bunch of other devices, which are not from Zigbee2MQTT but from OpenMQTTGateway.
On another RPi I have installed Home Assistant. I have connected this to my MQTT broker. The MQTT broker is able to add devices from my OpenMQTTGateway, but it does not add any of my Zigbee2MQTT devices.
I feel like I have tried everything and I don’t know where to look anymore. I don’t know if the problem has to do with Home Assistant or Zigbee2MQTT.
Many thanks in advance!
