I’ve installed zigbee2mqtt in order to control my IKEA Tradfri lights. Unfortunately the devices screen is stuck on ‘Loading, please wait’.
In the YAML configuration of the add-on I’ve already added:
experimental:
new_api: true
Because I have also issues using https on the ESPHOME add-on I suspect Ingress. for ESPHOME it is not possible to upload new settings to ESP32 device, the upload screen keeps blank. When I bypass ingres (e.g. goto http://10.10.2.1:6052/) it works fine.
How can I use the zigbee2mqtt devices screen and get rid of the ‘loading’ screen?
Thanks @francisp
I’ve ‘upgraded’ to the dev branch of Zigbee2mqtt and now zigbee2mqtt works fine!
To upgrade to the dev branch, you have to install the Home Assistant add-on “Zigbee2mqtt edge” I’ve disabled the production version of zigbee2mqtt (not sure if that is necessary).
