Hello - I am new to Zigbee, and I am trying to deploy homeassistant on my raspberry pi 4 (4GB). I bought the SONOFF Zigbee 3.0 USB Dongle Plus to expose a bunch of sensors previous owner of my house used with Xfinity. I have already checked, and they all seem to be compatible with Zigbee2MQTT. I setup Zigbee2MQTT following the official guide, but none of the sensors can be found (for ex. contact sensor). BTW them battery in them is new and they do get detected with other integrations (ZSWave, would prefer Z2M as it exposes battery and temper status, and has more compatibility) What am I missing?
Details:
Zigbee2MQTT:
Version: 1.22.1-1
Config:
data_path: /config/zigbee2mqtt
external_converters: []
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: true
mqtt:
base_topic: zigbee2mqtt
server: mqtt://core-mosquitto:1883
user: homeassistant
password: XXXXXX
serial:
port: /dev/ttyUSB0
advanced:
log_level: warn
pan_id: 6754
channel: 11
network_key:
- 1
- 3
- 5
- 7
- 9
- 11
- 13
- 15
- 0
- 2
- 4
- 6
- 8
- 10
- 12
- 13
availability_blocklist: []
availability_passlist: []
device_options: {}
blocklist: []
passlist: []
queue: {}
frontend:
port: 8099
experimental:
new_api: true
availability: false
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: '-d -d'
log: false
zigbee_herdsman_debug: false
Log:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] socat.sh: executing...
[16:16:57] INFO: Socat not enabled, marking service as down
[cont-init.d] socat.sh: exited 0.
[cont-init.d] zigbee2mqtt.sh: executing...
[16:16:58] INFO: MQTT available, fetching server detail ...
[16:16:58] INFO: Previous config file found, checking backup
[16:16:58] INFO: Creating backup config in '/config/zigbee2mqtt/.configuration.yaml.bk'
[16:16:58] INFO: Adjusting Zigbee2mqtt core yaml config with add-on quirks ...
[cont-init.d] zigbee2mqtt.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[16:16:59] INFO: Handing over control to Zigbee2mqtt Core ...
> [email protected] start
> node index.js
Zigbee2MQTT:warn 2021-12-23 16:17:05: `permit_join` set to `true` in configuration.yaml.
Zigbee2MQTT:warn 2021-12-23 16:17:06: Allowing new devices to join.
Zigbee2MQTT:warn 2021-12-23 16:17:06: Set `permit_join` to `false` once you joined all devices.
Zigbee2MQTT:warn 2021-12-23 16:17:06: Using experimental new availability feature
Mosquitto broker:
Version: 6.0.1
Config:
certfile: fullchain.pem
customize:
active: false
folder: mosquitto
keyfile: privkey.pem
logins: []
require_certificate: false
Log:
1640294226: New connection from 172.30.33.1 on port 1883.
1640294226: New client connected from 172.30.33.1 as mqttjs_ab98e734 (p2, c1, k60, u'homeassistant').
1640294301: New connection from 172.30.32.2 on port 1883.
1640294301: Socket error on client <unknown>, disconnecting.
1640294421: New connection from 172.30.32.2 on port 1883.
1640294421: Socket error on client <unknown>, disconnecting.
1640294541: New connection from 172.30.32.2 on port 1883.
HA configuration:
| version | core-2021.12.4 |
| installation_type | Home Assistant Supervised |
| dev | false |
| hassio | true |
| docker | true |
| user | root |
| virtualenv | false |
| python_version | 3.9.7 |
| os_name | Linux |
| os_version | 5.10.63-v7l+ |
| arch | armv7l |
| timezone | America/New_York |
Home Assistant Cloud
| logged_in | false |
| can_reach_cert_server | ok |
| can_reach_cloud_auth | ok |
| can_reach_cloud | ok |
Home Assistant Supervisor
| host_os | Raspbian GNU/Linux 10 (buster) |
| update_channel | stable |
| supervisor_version | supervisor-2021.12.2 |
| docker_version | 20.10.12 |
| disk_total | 234.5 GB |
| disk_used | 18.5 GB |
| healthy | true |
| supported | failed to load: Unsupported |
| supervisor_api | ok |
| version_api | ok |
| installed_addons | CEC Scanner (3.0), AirCast (3.2.0), Spotify Connect (0.10.0), ESPHome (2021.12.1), Zigbee2mqtt (1.22.1-1), Mosquitto broker (6.0.1) |
A couple of screenshots to show config/ issue:
