Zigbee2mqtt don't start (SRSP - SYS - ping after 6000ms). How to fix it?
zigbee2mqtt config:
data_path: /config/zigbee2mqtt
socat:
  enabled: false
  master: pty,raw,echo=0,link=/tmp/ttyACM0,mode=777
  slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
  options: "-d -d"
  log: false
mqtt: {}
serial:
  port: /dev/ttyACM0
zigbee2mqtt log:
[19:58:34] INFO: Preparing to start...
[19:58:34] INFO: Socat not enabled
[19:58:36] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info  2023-10-15 19:58:42: Logging to console and directory: '/config/zigbee2mqtt/log/2023-10-15.19-58-41' filename: log.txt
Zigbee2MQTT:info  2023-10-15 19:58:42: Starting Zigbee2MQTT version 1.33.1 (commit #unknown)
Zigbee2MQTT:info  2023-10-15 19:58:42: Starting zigbee-herdsman (0.19.0)
Zigbee2MQTT:error 2023-10-15 19:59:02: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2023-10-15 19:59:02: Failed to start zigbee
Zigbee2MQTT:error 2023-10-15 19:59:02: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2023-10-15 19:59:02: Exiting...
Zigbee2MQTT:error 2023-10-15 19:59:02: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
    at ZStackAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:103:27)
    at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:132:29)
    at Zigbee.start (/app/lib/zigbee.ts:60:27)
    at Controller.start (/app/lib/controller.ts:101:27)
    at start (/app/index.js:107:5)
Hardware:
    DEVLINKS: /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20221129160337-if00
      /dev/serial/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.3:1.0
    DEVNAME: /dev/ttyACM0
    DEVPATH: /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.0/tty/ttyACM0
    ID_BUS: usb
    ID_MODEL: SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2
    ID_MODEL_ENC: SONOFF\x20Zigbee\x203.0\x20USB\x20Dongle\x20Plus\x20V2
    ID_MODEL_ID: 55d4
    ID_PATH: platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.3:1.0
    ID_PATH_TAG: platform-fd500000_pcie-pci-0000_01_00_0-usb-0_1_3_1_0
    ID_REVISION: "0442"
    ID_SERIAL: ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20221129160337
    ID_SERIAL_SHORT: "20221129160337"
Add adapter: ezsp to you serial config. See the zigbee2mqtt documentation
Thank you :+1::+1::+1::+1::+1:
