Zigbee2MQTT Ember
Hi.
I am looking to move my ezsp to ember. When i try to start i see the errors below. I am running a Sky Connect adapter
21:15:25] INFO: Preparing to start...
[21:15:25] INFO: Socat not enabled
[21:15:25] INFO: Starting Zigbee2MQTT...
[2024-05-09 21:15:26] info: 	z2m: Logging to console, file (filename: log.log)
[2024-05-09 21:15:26] info: 	z2m: Starting Zigbee2MQTT version 1.37.0 (commit #unknown)
[2024-05-09 21:15:26] info: 	z2m: Starting zigbee-herdsman (0.45.0)
[2024-05-09 21:15:26] info: 	zh:ember: ======== Ember Adapter Starting ========
[2024-05-09 21:15:26] info: 	zh:ember:ezsp: ======== EZSP starting ========
[2024-05-09 21:15:26] info: 	zh:ember:uart:ash: ======== ASH NCP reset ========
[2024-05-09 21:15:26] info: 	zh:ember:uart:ash: Serial port opened
[2024-05-09 21:15:26] info: 	zh:ember:uart:ash: ======== ASH starting ========
[2024-05-09 21:15:27] info: 	zh:ember:uart:ash: ======== ASH connected ========
[2024-05-09 21:15:27] info: 	zh:ember:uart:ash: ======== ASH started ========
[2024-05-09 21:15:27] info: 	zh:ember:ezsp: ======== EZSP started ========
[2024-05-09 21:15:27] error: 	z2m: Error while starting zigbee-herdsman
[2024-05-09 21:15:27] error: 	z2m: Failed to start zigbee
[2024-05-09 21:15:27] error: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-05-09 21:15:27] error: 	z2m: Exiting...
[2024-05-09 21:15:28] error: 	z2m: Error: NCP EZSP protocol version of 9 does not match Host version 13
    at EmberAdapter.emberVersion (/app/node_modules/zigbee-
You need to flash new firmware to the skyconnect.
will applying the firmware wipe out my current Zigbee2MQTT setup?
No, it will not. FAQ | Zigbee2MQTT
