Zigbee2MQTT EnOcean Friends of Hue Switches
Hey all,
shortly i switched from the Philips Hue Bridge to the Sonoff Zigbee 3.0 USB Dongle.
My lamps are working and now i want to add my “Senic Friends of Hue” switches with the technology of EnOcean.
It should work, but my Zigbee2MQTT at Homeassistant don´t find that switches.
I deleted them from the Philips Hue app, that was enought to connect my lamps to MQTT, but it is not working with the switches.
Can someone of you help me in this case? Do i need to set the switches in a “pairing mode”? If yes, how can i do this?
Thank you in advance.
Have you read the notes here?
If these switches are “Green Power” devices then they don’t use standard zigbee and won’t work directly with zigbee2mqtt.
I have a whole bunch of Senic switches and I’m glad to report that they work great with Zigbee2MQTT.
They report as EnOcean PTM 215Z
However, they don’t work with ZHA at all. And even through the Hue integration connected to your bridge it only gives you 4 button functionality, whilst these are especially great for their both up/down action. If you press both buttons the Hue integration won’t even report an input.
I’m even in the process of switching from ZHA for that very reason. I love these things even though they have their weird quirks. Just being able to put them anywhere and not needing power ever is great.
Beware, they do need a Zigbee Green Power capable router device near like a Hue lightbulb connected to Zigbee2MQTT to pick up their messages.
I cant get the Seic switches to connect. I did the things mentioned on the z2mqqt website but it wont connect. in only have hue bulbs arround the house. There are hue bulbs 1 meter away from the switches but it still does not work. Can you explain how you did. it? :slight_smile:
zigbee2mqtt works with that, but you need a compatible zigbee stick.
I use the ConBee II Zigbee USB Dongle.
The Sonoff Zigbee 3.0 USB Dongle does not work. (I’m running two zigbee2mqtt instances, one for each stick)
Thank you so much for your help. Would it work with the Phoscon conBee 3 or just the 2? And even if it works with the 3. is it worth it to buy the 3 over the 2? :grimacing:
I’m using the Sonoff Zigbee dongle referred to as the “ZBDongle-P” which uses the TI CC2652P device and I have this working with an older EnOcean based device.
Here is my write-up
What features do they expose? Both single and long press?
Hi @wmaker, I have your same hardware: a Sonoff Dongle P and a Vimar 03906 (based on EnOcean PTM 215Z).
I am not able to discover the device (tried every channel), but I also do not have any Philips Hue devices in my network.
What is your situation? Are there any Philips Hue devices in your setup?
I am asking this because the zigbee2mqtt documentation about EnOcean PTM 215Z reports that “[…] the Green Power device has to be in range of a Philips Hue device in order to use it”.
Thanks!
You know, I forgot about that statement…but oh yeah a lot of Philips Hue devices near by my PTM 215Z.
Thank you!
At least now I know that before trying again I have to get some hue devices. :smile:
Best.
Hello Guys,
I am also somebody who is trying to escape from the Hue system. Luckily I have only the Hue hub (4 of them), not any other Philips product. I have around 80 3rd party Zigbee lights that work with the Hue and 40 Senic switches.
So my question is, will the Senic switch work with HA Green and the ConBee III USB dongle? If not what else would I need and which direction to take?
Hue wasn’t working reliably (sometimes lights remained off in a scene, sometimes they remained on. Quite hectic.) hence I would like to switch. I’m not a super techy guy to program all these things, so the most non-techy solution I would appreciate.
Thanks a lot for everyone who can put me into direction.
Conbee 3 seems to be compatible, since their list mentions multiple “Energy Harvesting switch without battery” devices, including the “GIRA Senic”, so you should be good to go.
https://phoscon.de/en/conbee3/compatible
Thanks RVD, I appreciate your feedback, so I have just ordered them.
Since researching the topic a bit more, Hue can only sync 10 lights at once, so this is probably the reason why my scenes are not working with it. In certain setups, I have circa 30 lights in a scene. (Living room, dining room, kitchen interconnected).
Do you know if there is such a limit with HA? Would I be able to set up scenes of 20+ lights at once without operational glitches?
I don’t think there is a limit.
(certainly nothing randomly chosen for commercial reasons)
The only actual limit I can think of is the bandwidth of your ZigBee network. If 20 lamps need to receive a command at the same time, you could verify the available bandwidth of ZigBee in the specifications.
Hi
I am using the PTM215Z switches. I am able to pair them with Z2MQTT but i am not able to get the working in an automation.
When i look at the logs, there is nothing happening when i press the buttons on the switch.
Anyone has a solution for this problem?
