i am using the zigbee2mqtt bridge to control some tradfri lights and getting values from xiaomi sensors. Today i wanted to make an automation to increase the brightness of a tradfri bulb.
But homeassistant seems to have a problem with the auto generated ids from zigbee2mqtt
I have this in my automation:
- service: light.turn_on
entity_id: light.0x000b57fffe305f71_light
data_template:
brightness: ‘{{states.light.0x000b57fffe305f71_light.attributes.brightness -50}}’
and homeassistant says:
Invalid config for [automation]: invalid template (TemplateSyntaxError: expected token ‘end of print statement’, got ‘x000b57fffe305f71_light’) for dictionary value @ data[‘action’][6][‘data_template’][‘brightness’]. Got None. (See /config/configuration.yaml, line 148). Please check the docs at https://home-assistant.io/components/automation/
Any suggestions?
