Hi Team.
I am having an issue with this BluePrint. The setup below works. Short press left is turning Light A off, long press left is turning Light B off. Short press right is turning Light A on and long press right is turning Light B on. All good there.
alias: James Bedroom - STYRBAR Remote control
description: James Bedroom
use_blueprint:
path: EPMatt/ikea_e2001_e2002.yaml
input:
integration: Zigbee2MQTT
controller_entity: sensor.mqtt_ikea_light_switch_james_bedroom_action
helper_last_controller_event: input_text.helper_last_controller_event
action_button_left_short:
- type: turn_off
device_id: f34fc20e537615538d30ecd324d28bef
entity_id: light.james_main_light
domain: light
action_button_left_long:
- type: turn_off
device_id: 5876888c6618fa957f931dcbd3063e5e
entity_id: light.james_changing_matt
domain: light
action_button_right_short:
- type: turn_on
device_id: dea6733b71c96d3ddf2fa2de19818daf
entity_id: light.james_bedroom
domain: light
brightness_pct: 100
action_button_right_long:
- type: turn_on
domain: light
brightness_pct: 25
However. I have then set the up button short and long press to increase the brightness. But what is happening is that on a long press right which should turn on Light B is now also turning on Light A
Any ideas?
use_blueprint:
input:
- type: turn_off
domain: light
- type: turn_off
domain: light
- type: turn_on
domain: light
brightness_pct: 100
- type: turn_on
domain: light
brightness_pct: 25
action_button_up_short:
- device_id: f34fc20e537615538d30ecd324d28bef
domain: light
type: brightness_increase
action_button_up_long:
- device_id: 5876888c6618fa957f931dcbd3063e5e
domain: light
