One of my devices is not connecting to Homeassistant after update.
Aqara double key wired wall switch (QBKG03LM).
Homeassistant problem or zigbee2mqtt?
Log:
2019-07-23 06:08:59 ERROR (MainThread) [homeassistant.components.mqtt.switch] Exception in async_discover when dispatching 'mqtt_discovery_new_switch_mqtt': ({'payload_off': 'OFF', 'payload_on': 'ON', 'value_template': '{{ value_json.state_left }}', 'command_topic': 'zigbee2mqtt/0x00158d00021608a7/left/set', 'command_topic_prefix': 'left', 'state_topic': 'zigbee2mqtt/0x00158d00021608a7', 'name': '0x00158d00021608a7_switch_left', 'unique_id': '0x00158d00021608a7_switch_left_zigbee2mqtt', 'device': {'identifiers': 'zigbee2mqtt_0x00158d00021608a7', 'name': '0x00158d00021608a7', 'sw_version': 'Zigbee2mqtt 1.1.1', 'model': 'Aqara double key wired wall switch (QBKG03LM)', 'manufacturer': 'Xiaomi'}, 'availability_topic': 'zigbee2mqtt/bridge/state', 'platform': 'mqtt'},)
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/mqtt/switch.py", line 59, in async_discover
config = PLATFORM_SCHEMA(discovery_payload)
File "/srv/homeassistant/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 254, in __call__
return self._compiled([], data)
File "/srv/homeassistant/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 551, in validate_dict
return base_validate(path, iteritems(data), out)
File "/srv/homeassistant/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 414, in validate_mapping
raise er.MultipleInvalid(errors)
voluptuous.error.MultipleInvalid: extra keys not allowed @ data['command_topic_prefix']
On zigbee2mqtt log:
Jul 23 06:20:40 hassbian npm[6848]: zigbee2mqtt:info 7/23/2019, 6:20:40 AM MQTT publish: topic 'homeassistant/switch/0x00158d00021608a7/switch_right/config', payload '{"payload_off":"OFF","payload_on":"ON","value_template":"{{ value_json.state_right }}","command_topic":"zigbee2mqtt/0x00158d00021608a7/right/set","command_topic_prefix":"right","state_topic":"zigbee2mqtt/0x00158d00021608a7","name":"0x00158d00021608a7_switch_right","unique_id":"0x00158d00021608a7_switch_right_zigbee2mqtt","device":{"identifiers":"zigbee2mqtt_0x00158d00021608a7","name":"0x00158d00021608a7","sw_version":"Zigbee2mqtt 1.1.1","model":"Aqara double key wired wall switch (QBKG03LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
And
Jul 23 06:31:40 hassbian npm[6848]: zigbee2mqtt:debug 7/23/2019, 6:31:40 AM Successfully pinged 0x00158d00021608a7
