Zigbee2MQTT Error: Failed to start zigbee
I’ve got the SONOFF Zigbee 3.0 USB Dongle Plus (‎ZBdongle-P). It’s connected via USB-Cable (0.5m) to RPI with Argon One M.2 SBC with SSD.
Here are the Logs from Zigbee2MQTT
[12:35:08] INFO: Preparing to start...
[12:35:08] INFO: Socat not enabled
[12:35:11] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info  2024-03-08 12:35:18: Logging to console and directory: '/config/zigbee2mqtt/log/2024-03-08.12-35-18' filename: log.txt
Zigbee2MQTT:info  2024-03-08 12:35:18: Starting Zigbee2MQTT version 1.36.0 (commit #unknown)
Zigbee2MQTT:info  2024-03-08 12:35:18: Starting zigbee-herdsman (0.35.1)
Zigbee2MQTT:error 2024-03-08 12:36:29: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2024-03-08 12:36:29: Failed to start zigbee
Zigbee2MQTT:error 2024-03-08 12:36:29: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2024-03-08 12:36:29: Exiting...
Zigbee2MQTT:error 2024-03-08 12:36:29: Error: Failure to connect
    at Ezsp.connect (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:373:19)
    at Driver.startup (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:163:13)
    at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:132:29)
    at Zigbee.start (/app/lib/zigbee.ts:62:27)
    at Controller.start (/app/lib/controller.ts:109:27)
    at start (/app/index.js:107:5)
Here are the configuration
data_path: /config/zigbee2mqtt
socat:
  enabled: false
  master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
  slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
  options: "-d -d"
  log: false
mqtt: {}
serial:
  port: /dev/ttyUSB0
Mosquitto is running with following logs:
[12:24:07] INFO: Successfully send discovery information to Home Assistant.
[12:24:08] INFO: Successfully send service information to the Supervisor.
2024-03-08 12:24:11: New connection from 172.30.32.1:44669 on port 1883.
2024-03-08 12:24:11: New client connected from 172.30.32.1:44669 as 06ETXrjgBGgfq2xwx9PhKK (p2, c1, k60, u'homeassistant').
2024-03-08 12:26:03: New connection from 172.30.32.2:38504 on port 1883.
2024-03-08 12:26:03: Client <unknown> closed its connection.
2024-03-08 12:28:03: New connection from 172.30.32.2:46138 on port 1883.
2024-03-08 12:28:03: Client <unknown> closed its connection.
2024-03-08 12:30:03: New connection from 172.30.32.2:36250 on port 1883.
2024-03-08 12:30:03: Client <unknown> closed its connection.
2024-03-08 12:32:03: New connection from 172.30.32.2:44016 on port 1883.
2024-03-08 12:32:03: Client <unknown> closed its connection.
2024-03-08 12:34:03: New connection from 172.30.32.2:38838 on port 1883.
2024-03-08 12:34:03: Client <unknown> closed its connection.
2024-03-08 12:36:03: New connection from 172.30.32.2:57566 on port 1883.
2024-03-08 12:36:03: Client <unknown> closed its connection.
2024-03-08 12:38:03: New connection from 172.30.32.2:36236 on port 1883.
2024-03-08 12:38:03: Client <unknown> closed its connection.
2024-03-08 12:40:03: New connection from 172.30.32.2:48364 on port 1883.
2024-03-08 12:40:03: Client <unknown> closed its connection.
2024-03-08 12:42:03: New connection from 172.30.32.2:47908 on port 1883.
2024-03-08 12:42:03: Client <unknown> closed its connection.
2024-03-08 12:44:03: New connection from 172.30.32.2:34526 on port 1883.
2024-03-08 12:44:03: Client <unknown> closed its connection.
2024-03-08 12:46:03: New connection from 172.30.32.2:54620 on port 1883.
2024-03-08 12:46:03: Client <unknown> closed its connection.
Seems Zigbee2MQTT thinks it is a EZSP-adapter (a Dongle-E)
try
serial:
  port: /dev/ttyUSB0
  adapter: zstack
thats it! thank you bud and have a nice weekend <3
