Am new to zigbee and homeassistant.
i am running my HA on raspberry4 and i ihave installed zigbee2mqtt and mqtt broker from addon.
When i go to zigbee to be able to add devices, i am getting this error message. How do i get this sorted out.
Zigbee2MQTT:error Not connected to MQTT server!
Zigbee2MQTT:warn : Received message from unsupported device with Zigbee model ‘TS0601’ and manufacturer name ‘_TZE200_cwnjrr’
Zigbee2MQTT:error 2021-12-19 11:47:15: Not connected to MQTT server!
Here is my config
external_converters: []
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: true
mqtt:
base_topic: zigbee2mqtt
server: mqtt://127.0.0.1:1883
user: mqyy_user
password: xxx
serial:
port: /dev/ttyACM0
advanced:
log_level: warn
pan_id: 6754
channel: 11
network_key:
- 1
- 3
- 5
- 7
- 9
- 11
- 13
- 15
- 0
- 2
- 4
- 6
- 8
- 10
- 12
- 13
availability_blocklist: []
availability_passlist: []
device_options: {}
blocklist: []
passlist: []
queue: {}
frontend:
port: 8099
experimental:
new_api: true
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: '-d -d'
log: false```
