I think since the last update of zigbee2mqtt, it doesn’t work properly anymore.
There is no error in mosquitto, but in the zigbee2mqtt log I have this:
Zigbee2MQTT:info 2023-02-12 08:59:33: Zigbee: disabling joining new devices.
Zigbee2MQTT:info 2023-02-12 08:59:33: Connecting to MQTT server at mqtt://192.168.178.35:1883
Zigbee2MQTT:error 2023-02-12 08:59:34: MQTT error: Connection refused: Not authorized
Zigbee2MQTT:error 2023-02-12 08:59:34: MQTT failed to connect, exiting...
Zigbee2MQTT:info 2023-02-12 08:59:34: Stopping zigbee-herdsman...
Zigbee2MQTT:info 2023-02-12 08:59:34: Stopped zigbee-herdsman
Mosquitto broker 6.1.3
Zigbee2MQTT 1.30.1-1
Home Assistant 2023.2.3
Supervisor 2023.01.1
Operating System 9.5
Interface utilisateur : 20230202.0 - latest
The settings have not changed.
Zigbee2mqtt :
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
mqtt:
base_topic: zigbee2mqtt
server: mqtt://192.168.178.35:1883
user: XXX
password: XXX
serial:
port: /dev/ttyACM0
Mosquitto :
logins: []
require_certificate: false
certfile: fullchain.pem
keyfile: privkey.pem
customize:
active: false
folder: mosquitto
I also have a 502 error on the web page of zigbee2mqtt.
thank you in advance for your help
