Zigbee2MQTT error when changing settings
I am trying to change the maximum distance or any other setting and keep getting this errror:
z2m: EventBus error 'Publish/mqttMessage': Cannot read properties of undefined (reading 'some')
Everything is up to to date, as of Sep 3, 2024. I just installed zigbee2mqtt update 2 days ago, I think the error wasn’t happening before that.
I restarted and even rebooted the mini PC I am using for HA but no luck.
anyone? Can somebody tell me what is the issue? IS ths bug with the newer update with Zigbee2MQTT?
If you ticked backup before it updated - roll back to check.
Thank you! Yes, I restored backed up version 1.39.1-1 and it works fine. It seems like Zigbee2MQTT version 1.40.0-1 breaks my Presence sensor model: TY_24G_Sensor_V2
How do I report this bug?
There is here :
https://github.com/zigbee2mqtt/hassio-zigbee2mqtt/issues
and here :
https://github.com/Koenkk/zigbee2mqtt/issues
For anyone getting the same error, koenkk has fixed the issue in dev branch and will be pushing a hotfix release soon (details).
it is now fixed in the regular version of Zigbee2MQTT as well 1.40.1.1
