goodevening,
I watched a tutorial on youtube to setup MQTT With my Sonoff USB dongle plus - E (Tutorial zigbee2mqtt) and it was very interesting but on 4:56 minuts i had to stop because i was running into an error. And after a while searching i couldn’t really found an answere so i thought maybe someone here can help me out.
When I start the Zigbee2Mqtt it starts, than crashes and closing automaticly.
I started the debugging tool and i found out this:
2023-08-01T20:58:40.798Z zigbee-herdsman:adapter:ezsp:uart -± waiting (1) success
2023-08-01T20:58:40.798Z zigbee-herdsman:adapter:ezsp:erro zdoRequest error
2023-08-01T20:58:40.799Z zigbee-herdsman:adapter:ezsp:debg Node descriptor request for ‘0’ failed (Error: ZdoRequest error), retry
at Driver.zdoRequest (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:573:19)
at EZSPAdapter.nodeDescriptorInternal (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/adapter/ezspAdapter.ts:373:28)
at Object.func (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/adapter/ezspAdapter.ts:363:32)
at Queue.executeNext (/app/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
My config file looks like this:
Socat (default)
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: “-d -d”
log: false
Mqtt
server: mqtt://core-mosquitto:1883
User: user account i created
password: password
Port:
port: >-
/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20220816162525-if00
adapter: ezsp
I had to flash my dongle to a much newer version to get mqtt working. it is now on version: 7.2.3.0
Please let me know if i need to give some more info.
edit: I also tried the Zigbee2mqtt Edge but that didnt make any diffrence
