Hi, I normally find my own way with these issues but am totally stumped.
I am trying to set-up a zigbee2MQTT configuration and then transfer my existing zigbee network to it. Unfortunately I am stuck at just getting zigbee2MQTT working. I have done the following:
- Deleted my existing zigbee network
- installed the add-ons mqtt & zigbee2mqtt. Created a new user mqtt-user, set the config:
mqtt:
server: mqtt://core-mosquitto:1883
user: mqtt-user
password: xxxxxxxx
Serial:
port: >-
/dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_1c8427bc4b12ef1186e775b8bf9df066-if00-port0
adapter: ember
- started Zigbee2MQTT
- Error:
[2024-12-20 21:59:47] error: z2m: Error while starting zigbee-herdsman
[2024-12-20 21:59:47] error: z2m: Failed to start zigbee
[2024-12-20 21:59:47] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-12-20 21:59:47] error: z2m: Exiting...
[2024-12-20 21:59:47] error: z2m: Error: Adapter EZSP protocol version (8) is not supported by Host [13-14].
at EmberAdapter.emberVersion (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1426:19)
at EmberAdapter.initEzsp (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:688:9)
at EmberAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1598:24)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:137:29)
at Zigbee.start (/app/lib/zigbee.ts:69:27)
at Controller.start (/app/lib/controller.ts:161:27)
at start (/app/index.js:154:5)
Things I have tried:
- using EZSP as the adaptor - get more errors: Failed to get 45df7312_zigbee2mqtt logs, network error
[2024-12-20 21:51:52] info: z2m:mqtt: MQTT publish: topic 'homeassistant/binary_sensor/1221051039810110150109113116116_0x7cc6b6fffef68cae/connection_state/config', payload '{"device":{"hw_version":"EZSP v8 6.10.3.0 build 297","identifiers":["zigbee2mqtt_bridge_0x7cc6b6fffef68cae"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.42.0"},"device_class":"connectivity","entity_category":"diagnostic","name":"Connection state","object_id":"zigbee2mqtt_bridge_connection_state","origin":{"name":"Zigbee2MQTT","sw":"1.42.0","url":"https://www.zigbee2mqtt.io"},"payload_off":"offline","payload_on":"online","state_topic":"zigbee2mqtt/bridge/state","unique_id":"bridge_0x7cc6b6fffef68cae_connection_state_zigbee2mqtt","value_template":"{{ value_json.state }}"}'
[2024-12-20 21:51:52] info: z2m:mqtt: MQTT publish: topic 'homeassistant/binary_sensor/1221051039810110150109113116116_0x7cc6b6fffef68cae/restart_required/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","device":{"hw_version":"EZSP v8 6.10.3.0 build 297","identifiers":["zigbee2mqtt_bridge_0x7cc6b6fffef68cae"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.42.0"},"device_class":"problem","enabled_by_default":false,"entity_category":"diagnostic","name":"Restart required","object_id":"zigbee2mqtt_bridge_restart_required","origin":{"name":"Zigbee2MQTT","sw":"1.42.0","url":"https://www.zigbee2mqtt.io"},"payload_off":false,"payload_on":true,"state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0x7cc6b6fffef68cae_restart_required_zigbee2mqtt","value_template":"{{ value_json.restart_required }}"}'
[2024-12-20 21:51:52] info: z2m:mqtt: MQTT publish: topic 'homeassistant/button/1221051039810110150109113116116_0x7cc6b6fffef68cae/restart/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","command_topic":"zigbee2mqtt/bridge/request/restart","device":{"hw_version":"EZSP v8 6.10.3.0 build 297","identifiers":["zigbee2mqtt_bridge_0x7cc6b6fffef68cae"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.42.0"},"device_class":"restart","name":"Restart","object_id":"zigbee2mqtt_bridge_restart","origin":{"name":"Zigbee2MQTT","sw":"1.42.0","url":"https://www.zigbee2mqtt.io"},"payload_press":"","unique_id":"bridge_0x7cc6b6fffef68cae_restart_zigbee2mqtt"}'
[2024-12-20 21:51:52] info: z2m:mqtt: MQTT publish: topic 'homeassistant/select/1221051039810110150109113116116_0x7cc6b6fffef68cae/log_level/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","command_template":"{\"options\": {\"advanced\": {\"log_level\": \"{{ value }}\" } } }","command_topic":"zigbee2mqtt/bridge/request/options","device":{"hw_version":"EZSP v8 6.10.3.0 build 297","identifiers":["zigbee2mqtt_bridge_0x7cc6b6fffef68cae"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.42.0"},"entity_category":"config","name":"Log level","object_id":"zigbee2mqtt_bridge_log_level","options":["error","warning","info","debug"],"origin":{"name":"Zigbee2MQTT","sw":"1.42.0","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0x7cc6b6fffef68cae_log_level_zigbee2mqtt","value_template":"{{ value_json.log_level | lower }}"}'
[2024-12-20 21:51:52] info: z2m:mqtt: MQTT publish: topic 'homeassistant/sensor/1221051039810110150109113116116_0x7cc6b6fffef68cae/version/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","device":{"hw_version":"EZSP v8 6.10.3.0 build 297","identifiers":["zigbee2mqtt_bridge_0x7cc6b6fffef68cae"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.42.0"},"entity_category":"diagnostic","icon":"mdi:zigbee","name":"Version","object_id":"zigbee2mqtt_bridge_version","origin":{"name":"Zigbee2MQTT","sw":"1.42.0","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0x7cc6b6fffef68cae_version_zigbee2mqtt","value_template":"{{ value_json.version }}"}'
[2024-12-20 21:51:52] info: z2m:mqtt: MQTT publish: topic 'homeassistant/sensor/1221051039810110150109113116116_0x7cc6b6fffef68cae/coordinator_version/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","device":{"hw_version":"EZSP v8 6.10.3.0 build 297","identifiers":["zigbee2mqtt_bridge_0x7cc6b6fffef68cae"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.42.0"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:chip","name":"Coordinator version","object_id":"zigbee2mqtt_bridge_coordinator_version","origin":{"name":"Zigbee2MQTT","sw":"1.42.0","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0x7cc6b6fffef68cae_coordinator_version_zigbee2mqtt","value_template":"{{ value_json.coordinator.meta.revision }}"}'
[2024-12-20 21:51:52] info: z2m:mqtt: MQTT publish: topic 'homeassistant/sensor/1221051039810110150109113116116_0x7cc6b6fffef68cae/network_map/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","device":{"hw_version":"EZSP v8 6.10.3.0 build 297","identifiers":["zigbee2mqtt_bridge_0x7cc6b6fffef68cae"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.42.0"},"enabled_by_default":false,"entity_category":"diagnostic","json_attributes_template":"{{ value_json.data.value | tojson }}","json_attributes_topic":"zigbee2mqtt/bridge/response/networkmap","name":"Network map","object_id":"zigbee2mqtt_bridge_network_map","origin":{"name":"Zigbee2MQTT","sw":"1.42.0","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/bridge/response/networkmap","unique_id":"bridge_0x7cc6b6fffef68cae_network_map_zigbee2mqtt","value_template":"{{ now().strftime('%Y-%m-%d %H:%M:%S') }}"}'
[2024-12-20 21:51:52] info: z2m:mqtt: MQTT publish: topic 'homeassistant/sensor/1221051039810110150109113116116_0x7cc6b6fffef68cae/permit_join_timeout/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","device":{"hw_version":"EZSP v8 6.10.3.0 build 297","identifiers":["zigbee2mqtt_bridge_0x7cc6b6fffef68cae"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.42.0"},"device_class":"duration","entity_category":"diagnostic","name":"Permit join timeout","object_id":"zigbee2mqtt_bridge_permit_join_timeout","origin":{"name":"Zigbee2MQTT","sw":"1.42.0","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0x7cc6b6fffef68cae_permit_join_timeout_zigbee2mqtt","unit_of_measurement":"s","value_template":"{{ iif(value_json.permit_join_timeout is defined, value_json.permit_join_timeout, None) }}"}'
[2024-12-20 21:51:52] info: z2m:mqtt: MQTT publish: topic 'homeassistant/switch/1221051039810110150109113116116_0x7cc6b6fffef68cae/permit_join/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","command_topic":"zigbee2mqtt/bridge/request/permit_join","device":{"hw_version":"EZSP v8 6.10.3.0 build 297","identifiers":["zigbee2mqtt_bridge_0x7cc6b6fffef68cae"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.42.0"},"icon":"mdi:human-greeting-proximity","name":"Permit join","object_id":"zigbee2mqtt_bridge_permit_join","origin":{"name":"Zigbee2MQTT","sw":"1.42.0","url":"https://www.zigbee2mqtt.io"},"payload_off":"false","payload_on":"true","state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0x7cc6b6fffef68cae_permit_join_zigbee2mqtt","value_template":"{{ value_json.permit_join | lower }}"}'
[2024-12-20 21:59:11] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"offline"}'
[2024-12-20 21:59:11] info: z2m: Disconnecting from MQTT server
[2024-12-20 21:59:11] info: z2m: Stopping zigbee-herdsman...
[2024-12-20 21:59:11] info: zh:controller: Wrote coordinator backup to '/config/zigbee2mqtt/coordinator_backup.json'
[2024-12-20 21:59:11] info: z2m: Stopped zigbee-herdsman
[2024-12-20 21:59:11] info: z2m: Stopped Zigbee2MQTT
- Using my Skyconnect dongle instead of my sonoff - same errors (this is on the latest firmware)
- Updating my Sonoff Firmware - but cannot get it to update. a) Tried the online tool using Windows - get an error saying it cannot determine existing firmware b) Tried SecureCRT but again despite clicking into boot mode it would not respond despite the LED flashing green. C) tried using silicon Lab flasher.
It is a brand new dongle (arrived from amazon yesterday - so I assume it has a decent firmware on it?)
Where do I even go next? What do I try?
