Hi i have a problem with a Ziggbee device @Zigbee2mqtt. The device is in the supported list from Zigbee2MQTT
Here is my log file:
Failed to configure ‘0x0015bc001b1009a1’, attempt 1 (Error: {“address”:40026,“clusterId”:32801,“sequence”:15} after 10000ms at Object.start (/app/node_modules/zigbee-herdsman/src/utils/waitress.ts:63:23) at Driver.zdoRequest (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:667:43) at /app/node_modules/zigbee-herdsman/src/adapter/ezsp/adapter/ezspAdapter.ts:566:13 at Queue.execute (/app/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20) at Endpoint.bind (/app/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:551:13) at Object.bind (/app/node_modules/zigbee-herdsman-converters/src/lib/reporting.ts:43:9) at Object.configure (/app/node_modules/zigbee-herdsman-converters/src/devices/frient.ts:18:13) at Configure.configure (/app/lib/extension/configure.ts:120:13) at Configure.onMQTTMessage (/app/lib/extension/configure.ts:55:21) at EventEmitter.wrappedCallback (/app/lib/eventBus.ts:174:17))
