Zigbee2MQTT: Failed to start EZSP layer with status=HOST_FATAL_ERROR
Hi, everyone,
I wonder if anyone has tried this usb dondle recently. Sonoff_Zigbee_3.0_USB_Dongle_Plus
I have tried both port methods. No luck. I do not have a complicated setup. This is the first few add-ons I am using. It looks the default firmware support Zigbee2MQTT based on the research. Any ideas? thanks.
Device info
CC2652
by Texas Instruments
Firmware: Z-Stack 20210708
Zigbee info
IEEE: 00:12:4b:00:30:db:20:d8
Nwk: 0x0000
Device Type: Coordinator
LQI: Unknown
RSSI: Unknown
Last seen: 2024-12-15T10:53:17
Power source: Mains
serial:
port: >-
/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0e8e20082755ef1189404e73cc32aab1-if00-port0
adapter: ember
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: “-d -d”
log: false
mqtt: {}
serial:
port: /dev/ttyUSB0
adapter: ember
[13:55:27] INFO: Preparing to start…
[13:55:27] INFO: Socat not enabled
[13:55:27] INFO: Starting Zigbee2MQTT…
Starting Zigbee2MQTT without watchdog.
[2024-12-15 13:55:33] info: z2m: Logging to console, file (filename: log.log)
[2024-12-15 13:55:33] info: z2m: Starting Zigbee2MQTT version 1.42.0 (commit #unknown)
[2024-12-15 13:55:33] info: z2m: Starting zigbee-herdsman (2.1.9)
[2024-12-15 13:55:33] info: zh:ember: Using default stack config.
[2024-12-15 13:55:33] info: zh:ember: ======== Ember Adapter Starting ========
[2024-12-15 13:55:33] info: zh:ember:ezsp: ======== EZSP starting ========
[2024-12-15 13:55:33] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2024-12-15 13:55:33] info: zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
[2024-12-15 13:55:33] info: zh:ember:uart:ash: Serial port opened
[2024-12-15 13:55:33] info: zh:ember:uart:ash: ======== ASH starting ========
[2024-12-15 13:55:36] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2024-12-15 13:55:36] info: zh:ember:uart:ash: ======== ASH starting ========
[2024-12-15 13:55:38] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2024-12-15 13:55:38] info: zh:ember:uart:ash: ======== ASH starting ========
[2024-12-15 13:55:41] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2024-12-15 13:55:41] info: zh:ember:uart:ash: ======== ASH starting ========
[2024-12-15 13:55:43] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2024-12-15 13:55:43] info: zh:ember:uart:ash: ======== ASH starting ========
[2024-12-15 13:55:46] error: z2m: Error while starting zigbee-herdsman
[2024-12-15 13:55:46] error: z2m: Failed to start zigbee
[2024-12-15 13:55:46] error: z2m: Check Zigbee2MQTT fails to start | Zigbee2MQTT for possible solutions
[2024-12-15 13:55:46] error: z2m: Exiting…
[2024-12-15 13:55:46] error: z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
at EmberAdapter.initEzsp (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:684:19)
at EmberAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1598:24)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:137:29)
at Zigbee.start (/app/lib/zigbee.ts:69:27)
at Controller.start (/app/lib/controller.ts:161:27)
at start (/app/index.js:154:5)
Hello, merry Christmas !
I had the same log error, using
ID_USB_MODEL: Sonoff_Zigbee_3.0_USB_Dongle_Plus
ID_USB_MODEL_ENC: Sonoff\x20Zigbee\x203.0\x20USB\x20Dongle\x20Plus
[15:15:04] INFO: Preparing to start…
[15:15:04] INFO: Socat not enabled
[15:15:05] INFO: Starting Zigbee2MQTT…
[2024-12-25 15:15:10] info: z2m: Logging to console, file (filename: log.log)
[2024-12-25 15:15:10] info: z2m: Starting Zigbee2MQTT version 1.42.0 (commit #unknown)
[2024-12-25 15:15:10] info: z2m: Starting zigbee-herdsman (2.1.9)
[2024-12-25 15:15:11] info: zh:ember: Using default stack config.
[2024-12-25 15:15:11] info: zh:ember: ======== Ember Adapter Starting ========
[2024-12-25 15:15:11] info: zh:ember:ezsp: ======== EZSP starting ========
[2024-12-25 15:15:11] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2024-12-25 15:15:11] info: zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
[2024-12-25 15:15:11] info: zh:ember:uart:ash: Serial port opened
[2024-12-25 15:15:11] info: zh:ember:uart:ash: ======== ASH starting ========
[2024-12-25 15:15:14] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2024-12-25 15:15:14] info: zh:ember:uart:ash: ======== ASH starting ========
[2024-12-25 15:15:16] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2024-12-25 15:15:16] info: zh:ember:uart:ash: ======== ASH starting ========
[2024-12-25 15:15:19] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2024-12-25 15:15:19] info: zh:ember:uart:ash: ======== ASH starting ========
[2024-12-25 15:15:21] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2024-12-25 15:15:21] info: zh:ember:uart:ash: ======== ASH starting ========
[2024-12-25 15:15:24] error: z2m: Error while starting zigbee-herdsman
[2024-12-25 15:15:24] error: z2m: Failed to start zigbee
[2024-12-25 15:15:24] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-12-25 15:15:24] error: z2m: Exiting…
[2024-12-25 15:15:24] error: z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
Any idear to help ?
