I have just purchased a Conbee II stick and followed this video to get it set up in HA with Zigbee2Mqtt however Z2m will not start Zigbee. I get the following in the logs:
[07:40:05] INFO: Handing over control to Zigbee2MQTT Core ...
Zigbee2MQTT:info 2022-09-14 07:40:06: Logging to console and directory: '/config/zigbee2mqtt/log/2022-09-14.07-40-06' filename: log.txt
Zigbee2MQTT:info 2022-09-14 07:40:06: Starting Zigbee2MQTT version 1.27.2 (commit #unknown)
Zigbee2MQTT:info 2022-09-14 07:40:06: Starting zigbee-herdsman (0.14.53)
Zigbee2MQTT:error 2022-09-14 07:40:06: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2022-09-14 07:40:06: Failed to start zigbee
Zigbee2MQTT:error 2022-09-14 07:40:06: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2022-09-14 07:40:06: Exiting...
Zigbee2MQTT:error 2022-09-14 07:40:06: Error: spawn udevadm ENOENT
at Process.ChildProcess._handle.onexit (node:internal/child_process:283:19)
at onErrorNT (node:internal/child_process:478:16)
at processTicksAndRejections (node:internal/process/task_queues:83:21)
[07:40:07] INFO: Handing over control to Zigbee2MQTT Core ...
Here is my config.yaml:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
mqtt:
port: mqtt://core-mosquitto
username: mqtt-user
password: Password123
serial:
port: >-
/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2287395-if00
adapter: deconz
I have tried:
- A completely fresh install of HA
- Adding the mqtt-user to Moquitto
- giving all users full access to the conbee stick with âsudo chmod a+rwx /dev/ttyACM0â
- flashing the latest firmware to the Conbee II stick
Itâs hard for me to tell if this is a problem with the Conbee stick or a configuration problem with my HA/Z2M/Mosquitto Installation but I have heard good things about the Sonof 3.0 stick.
Does anybody see anything obvious that I am missing?
but donât mind I learnd similarly.
