I’m sure this is going to be something fairly simple but I’m going round and round in circles trying to resolve this, so looking for a little help if possible please?
Runnning HA OS on an Intel NUC
Home Assistant 2022.9.6
Supervisor 2022.09.1
Operating System 9.0
Frontend 20220907.2 - latest
and also Zigbee2MQTT 1.27.2-1
My Zigbee coordinator is a Sonoff ZBBridge flashed with Tasmota. I have a handful of Zigbee devices which have been working flawlessly.
Today I browsed to my Zigbee coordinator webpage and noticed it was still on an older version of Tasmota, V10, so I decided to do an OTA update to V12.1.1 which flashed fine.
I was prepared to have to re-pair my handful of Zigbee devices to the coordinator, which I have done successfully, and can see the devices communicating in the console of the coordinator, however performing this Tasmota update on the coordinator seems to have caused problems with Zigbee2MQTT in Home Assistant.
Zigbee2MQTT no longer loads the webUI and I get a 502 error, and the Add-on logs show
Zigbee2MQTT:info 2022-09-25 16:07:03: Starting Zigbee2MQTT version 1.27.2 (commit #unknown)
Zigbee2MQTT:info 2022-09-25 16:07:03: Starting zigbee-herdsman (0.14.53)
Zigbee2MQTT:debug 2022-09-25 16:07:03: Using zigbee-herdsman with settings: '{"adapter":{"concurrent":null,"delay":null,"disableLED":false},"backupPath":"/config/zigbee2mqtt/coordinator_backup.json","databaseBackupPath":"/config/zigbee2mqtt/database.db.backup","databasePath":"/config/zigbee2mqtt/database.db","network":{"channelList":[11],"extendedPanID":[221,221,221,221,221,221,221,221],"networkKey":"HIDDEN","panID":6754},"serialPort":{"adapter":"ezsp","path":"tcp://192.168.1.193:8888"}}'
Zigbee2MQTT:error 2022-09-25 16:07:03: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2022-09-25 16:07:03: Failed to start zigbee
Zigbee2MQTT:error 2022-09-25 16:07:03: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2022-09-25 16:07:03: Exiting...
Zigbee2MQTT:error 2022-09-25 16:07:03: Error: Error while opening socket
at Socket.<anonymous> (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:146:24)
at Socket.emit (node:events:539:35)
at emitErrorNT (node:internal/streams/destroy:157:8)
at emitErrorCloseNT (node:internal/streams/destroy:122:3)
at processTicksAndRejections (node:internal/process/task_queues:83:21)
I’ve followed the link suggested for the Z2M fails to start page but cannot find a solution.
I’ve tried uninstalling Z2M and reinstalling, but no difference. I have also restored yesterdays full backup of HA but again no difference, so I’m wondering how this coordinator firmware update could be breaking things in HA?
