Hello!
In August I started with HA on an intel nuc with a Sonoff Zigbee USB dongle.
Back then, I had no issues connecting an IKEA Symfonisk remote to HA. It just worked. But I had to pause with HA until yesterday.
Then, yesterday I tried to use the remote again and nothing works.
I did system updates, so I’m running latest HA, Mosquito broker, Zigbee2MQTT.
I have difficulties with pairing and the configuration always fails.
I reinstalled Mosquito and Zigbee2MQTT several times, force removed the remote.
Pairing took me several attempts yesterday but never got completed.
Today, I make it until the error message below.
Any idea what I’m doing wrong? I’m surprised because in August everything just worked fine. Now I can’t even get a pairing completed.
I’m sure, I did not give sufficient information, but I’m too new to HA, so please ask for whatever is missing and I’ll do my best to answer.
Thanks in advance!
Zigbee2MQTT log:
error 2024-10-22 14:45:08z2m: Failed to configure 'Symfonisk', attempt 3
(Error: Bind 0x0cae5ffffe5f15cb/1 genPollCtrl from '0x00124b0030ca66e5/1' failed (AREQ - ZDO - bindRsp after 10000ms) at Object.start
(/app/node_modules/zigbee-herdsman/src/utils/waitress.ts:59:23) at /app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:403:47
at Queue.execute (/app/node_modules/zigbee-herdsman/src/utils/queue.ts:36:20) at ZStackAdapter.sendZdo (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:311:16)
at Endpoint.bind (/app/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:563:30) at configure
(/app/node_modules/zigbee-herdsman-converters/src/lib/modernExtend.ts:178:17) at Object.configure (/app/node_modules/zigbee-herdsman-converters/src/index.ts:205:21)
at Configure.configure (/app/lib/extension/configure.ts:130:13) at Configure.onMQTTMessage (/app/lib/extension/configure.ts:57:21) at EventEmitter.wrappedCallback (/app/lib/eventBus.ts:206:17))
info 2024-10-22 14:45:08z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/response/device/configure', payload '{"data":{"id":"Symfonisk"},
"error":"Failed to configure (Bind 0x0cae5ffffe5f15cb/1 genPollCtrl from '0x00124b0030ca66e5/1' failed (AREQ - ZDO - bindRsp after 10000ms))","status":"error","transaction":"v25kh-1"}'
