I am running Haas in supervisor mode on a raspberry pi. I got supervisor mode running following https://peyanski.com/how-to-install-home-assistant-supervised-official-way/ (i.e., I am not running haas OS).
I had gotten everything working with my sonoff USB dongle and a bunch of sonoff devices. However recently zigbee2mqtt appears to have stopped working with the following errors in the log:
> [email protected] start
> node index.js
(node:8164) UnhandledPromiseRejectionWarning: Error: ENOENT: no such file or directory, open 'null/configuration.yaml'
at Object.openSync (fs.js:497:3)
at Object.readFileSync (fs.js:393:35)
at Object.read (/app/lib/util/yaml.ts:7:29)
at read (/app/lib/util/settings.ts:310:20)
at getInternalSettings (/app/lib/util/settings.ts:406:21)
at Object.reRead (/app/lib/util/settings.ts:684:5)
at start (/app/index.js:85:14)
(Use `node --trace-warnings ...` to show where the warning was created)
(node:8164) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
(node:8164) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
[20:23:49] INFO: Handing over control to Zigbee2mqtt Core ...
I am not able to figure out why it trying to find configuration.yaml in a null location. Below is the config:
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: '-d -d'
log: false
mqtt:
base_topic: zigbee2mqtt
user: <mqtt_user>
password: <mqtt_password>
serial:
port: /dev/ttyUSB0
external_converters: []
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: false
advanced:
log_level: debug
pan_id: 6754
channel: 11
network_key:
- 1
- 3
- 5
- 7
- 9
- 11
- 13
- 15
- 0
- 2
- 4
- 6
- 8
- 10
- 12
- 13
availability_blocklist: []
availability_passlist: []
device_options: {}
blocklist: []
passlist: []
queue: {}
frontend:
port: 8099
experimental: {}
availability: false
