Just upgraded to Home Assistant OS 5.11, supervisor-2021.02.6, core-2021.2.2.
Zigbee2MQTT add-on is now failing to start with the following error:
— begin log —
ERR!
code ELIFECYCLE
npm ERR! errno 1
npm
ERR!
[email protected] start: node index.js
npm
ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm
ERR!
A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2021-02-11T05_09_07_959Z-debug.log
2021-02-10T21:09:09: PM2 log: App [npm:0] exited with code [1] via signal [SIGINT]
2021-02-10T21:09:09: PM2 log: App [npm:0] starting in -fork mode-
2021-02-10T21:09:09: PM2 log: App [npm:0] online
[email protected] start /zigbee2mqtt-1.17.1
node index.js
Zigbee2MQTT:info 2021-02-10 21:09:10: Logging to console and directory: ‘/share/zigbee2mqtt/log/2021-02-10.21-09-10’ filename: log.txt
Zigbee2MQTT:info 2021-02-10 21:09:11: Starting Zigbee2MQTT version 1.17.1 (commit #1.17.1)
Zigbee2MQTT:info 2021-02-10 21:09:11: Starting zigbee-herdsman (0.13.59)
Zigbee2MQTT:error 2021-02-10 21:09:11: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2021-02-10 21:09:11: Failed to start zigbee
Zigbee2MQTT:error 2021-02-10 21:09:11: Exiting…
Zigbee2MQTT:error 2021-02-10 21:09:11: Error: Error while opening serialport ‘Error: Error: Operation not permitted, cannot open /dev/ttyS2’
at Znp. (/zigbee2mqtt-1.17.1/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
at Generator.next ()
at /zigbee2mqtt-1.17.1/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
at new Promise ()
at __awaiter (/zigbee2mqtt-1.17.1/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
at SerialPort. (/zigbee2mqtt-1.17.1/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
at SerialPort._error (/zigbee2mqtt-1.17.1/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
at /zigbee2mqtt-1.17.1/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
— end log —
The debug log in /root/.npm doesn’t exist (the .npm directory doesn’t even exist).
Another curiosity: As part of debugging protocol, I set Zigbee2MQTT “Start at boot” option to false and I still get this error on boot. I am surprised that the add-on still seems to be trying to run at boot.
