Zigbee2MQTT failure
hi, i have a lot of zigbee devices, automation’s, and so on. Until recently everything worked out fine but lately some of the automation’s (sometimes) don’t work.
I also get a lot of red messages in my Zigbee2MQTT overview.
I don’t know if these are the reason for the devices to not react on a automation like eg motion censored lights.
I’ll put a list of latest popups here. (Don’t see how to put them into a file)
Hope someone can help me because the family is losing their believe in Home assistant :slight_smile:
Please be aware that i’m new to this and want to learn but my knowledge is poor.
error 2025-01-27 20:57:10zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
error 2025-01-27 20:57:10zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
error 2025-01-27 20:57:12zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
error 2025-01-27 20:57:12zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
error 2025-01-27 20:58:26zh:ezsp:uart: --> Error: Error: {"sequence":7} after 4000ms
error 2025-01-27 20:58:26zh:ezsp:uart: -!- break waiting (7)
error 2025-01-27 20:58:26zh:ezsp:uart: Can't send DATA frame (6,3,0): 8e00010500
error 2025-01-27 20:58:43zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
error 2025-01-27 20:58:43zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
error 2025-01-27 20:58:44zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
error 2025-01-27 20:58:44zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
error 2025-01-27 20:58:45zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
error 2025-01-27 20:58:45zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
error 2025-01-27 20:58:46zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
error 2025-01-27 20:58:46zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
error 2025-01-27 20:58:47zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
error 2025-01-27 20:58:47zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
error 2025-01-27 20:58:48zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
error 2025-01-27 20:58:48zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
error 2025-01-27 20:58:49zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
error 2025-01-27 20:58:49zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
error 2025-01-27 20:58:50zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
error 2025-01-27 20:58:50zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
error 2025-01-27 20:58:51zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
error 2025-01-27 20:58:51zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
error 2025-01-27 20:58:52zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
error 2025-01-27 20:58:52zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
error 2025-01-27 20:58:53zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
error 2025-01-27 20:58:53zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
error 2025-01-27 20:58:54zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
error 2025-01-27 20:58:54zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
error 2025-01-27 20:58:55zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
error 2025-01-27 20:58:55zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
error 2025-01-27 20:58:56zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
error 2025-01-27 20:58:56zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
Recently my zigbee2mqtt don’t work anymore. (It worked flawlessly during 2 years)
I have the same errors in log:
[2025-01-30 08:49:23] error: zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
[2025-01-30 08:49:23] error: zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
[2025-01-30 08:50:55] error: zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
[2025-01-30 08:50:55] error: zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
[2025-01-30 08:51:55] error: zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
[2025-01-30 08:51:55] error: zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
[2025-01-30 08:55:35] error: zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
[2025-01-30 08:55:35] error: zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
[2025-01-30 08:58:23] error: zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
[2025-01-30 08:58:23] error: zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
[2025-01-30 09:15:00] error: zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
[2025-01-30 09:15:00] error: zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
[2025-01-30 09:16:00] error: zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
[2025-01-30 09:16:00] error: zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
[2025-01-30 09:17:40] error: zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
[2025-01-30 09:17:40] error: zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
[2025-01-30 09:29:19] error: zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
[2025-01-30 09:29:19] error: zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
[2025-01-30 09:45:20] error: zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
[2025-01-30 09:45:20] error: zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
[2025-01-30 09:53:20] error: zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
[2025-01-30 09:53:20] error: zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
[2025-01-30 09:54:20] error: zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
[2025-01-30 09:54:20] error: zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
[2025-01-30 10:01:20] error: zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
[2025-01-30 10:01:20] error: zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
[2025-01-30 10:18:04] error: zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
[2025-01-30 10:18:04] error: zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
[2025-01-30 10:24:20] error: zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
[2025-01-30 10:24:20] error: zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
[2025-01-30 10:34:08] error: zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
[2025-01-30 10:34:08] error: zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
[2025-01-30 10:51:00] error: zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
[2025-01-30 10:51:00] error: zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
I have a sonfoff dongle E. I upgrade the firmware and switched from EZSP to ember.
This has fixed the issue.
I followed this video : https://www.youtube.com/watch?v=x1QeNPi6tK8
Thank’s Hcouplet,
I followed your advise and the youtube link.
This worked out for me after removing the backup files.
I was a bit confused because the driver still mention EZSP and you manualy have to change this to Ember.
Now see if this solves some of my problems with lightbulbs and sensors which now sometimes don’t work.
Marc
Hi, were you using tuya mmwave sensors?
