hello, i use zigbee2mqtt and the firmwareupdate does failed,
i have some ledvance A60 DIM T E27 bulbs. can anyone help me please?
…sorry for my english
Update of 'kugel wohnen' failed (The value of "offset" is out of range. It must be >= 0 and <= 188380. Received 188384)
I have the same problem. I cannot find a solution for this for months. Using Zigbee2MQTT.
I have several LED bulbs:
Zigbee Model A60 DIM T Zigbee Manufacturer LEDVANCE Description SMART+ Classic A E27 dimmable white
If you go to the Levance site here and search for the model: A60 DIM T
There is a match, and you can download the .OTA firmware manually:
I tried setting that update URL manually, even the direct .OTA firmware file. It makes no difference. Some errors as the above posters, ends with:
It seems like the firmware is either incorrect or a mismatch, or just some Home Assistant bug that is not letting you update the firmware.
Has anyone found a solution for this? Is the firmware even available? Because I get a notification, there is an update available both from Home Assistant and Zigbee2MQTT.
Updating from Home Assistant does not work. From Zigbee2MQTT, I get the above posted error.
