Zigbee2MQTT for HA Yellow
I read online that Zigbee2MQTT Integration works better than the Zigbee Integration in HA. I see that people use Sonoff dongle and then configure Zigbee2MQTT Integration using that dongle. I am setting up HA Yellow Kit, which has Zigbee protocol built-in. Do I still need the Sonoff dongle for Zigbee2MQTT Integration or it can be configured using the built-in Zigbee interface? If I can use the built-in Zigbee, then can someone provide the configuration steps for it?
Here you go. The best place to start is usually the docs for Z2M EmberZNet adapters (Silicon Labs) | Zigbee2MQTT
Thank you, ShadowFist!
