I was a “happy customer” of zigbee2mqtt till last week… something happen (maybe an update) and my entire zigbee network started to fail…
Initially I thought that it was a hardware failure, so:
- swopped the old TI USB with a new one (Texas_Instruments_TI_CC2531_USB)
- purchased a new one ( zig-a-zig-ah! – usb-1a86_USB)
but no luck
Then I thought of a SW issue, so I decided to wipe out the Raspberry pi and reinstalling everything from scratch… again no luck
Now what I have done after re-installing is the following:
- Installed and configure Mosquitto broker add-on (simply added a dedicated user and password and started → no error in log)
- Installed ZigBee2MQTT add-on and performed the followings:
- edited config file as below
mqtt:
base_topic: zigbee2mqtt
server: mqtt://localhost:1883
user: mqttuser
password: mqttPassword
serial:
port: /dev/ttyACM0
- Checked the Log and found the following:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] socat.sh: executing...
[09:39:54] INFO: Socat not enabled, marking service as down
[cont-init.d] socat.sh: exited 0.
[cont-init.d] zigbee2mqtt.sh: executing...
[09:39:56] INFO: MQTT available, fetching server detail ...
[09:39:57] INFO: Previous config file found, checking backup
[09:39:57] INFO: Creating backup config in '/config/zigbee2mqtt/.configuration.yaml.bk'
[09:39:57] INFO: Adjusting Zigbee2mqtt core yaml config with add-on quirks ...
[cont-init.d] zigbee2mqtt.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[09:40:00] INFO: Handing over control to Zigbee2mqtt Core ...
> [email protected] start /app
> node index.js
Zigbee2MQTT:error 2021-06-16 09:40:50: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2021-06-16 09:40:50: Failed to start zigbee
Zigbee2MQTT:error 2021-06-16 09:40:50: Check https://www.zigbee2mqtt.io/information/FAQ.html#help-zigbee2mqtt-fails-to-start for possible solutions
Zigbee2MQTT:error 2021-06-16 09:40:50: Exiting...
Zigbee2MQTT:error 2021-06-16 09:40:50: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
at ZStackAdapter.<anonymous> (/app/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:93:31)
at Generator.throw (<anonymous>)
at rejected (/app/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:25:65)
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! [email protected] start: `node index.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2021-06-16T05_41_25_962Z-debug.log
[09:41:26] INFO: Handing over control to Zigbee2mqtt Core ...
And when I try to open ZigBee2MQTT we interface I get 502: Bad Gateway
What am I doing wrong? I saw many people had similar issues in the past, but I could not really find a “unique solution”…
any suggestion would be much appreciated
Thank you
