I noticed the same with my cube connected with the Xiaomi Gateway as well. When I shook the Cube my Gateway responded with a Chinese voice and after a few seconds, the cube was working again.
Yeah, seems to be something buggy with my server. Will use a left-over pi instead
To answer my own question, there now seems to be firmware to make a CC2531 or CC2530 work as a router/repeater. I noticed this page:
I havenāt tried it yet personally, but will when my next CC2531 arrives.
Iāve deleted a Xiaomi wireless switch from configuration.yaml and now I want to add again. When I reset the wireless switch (blue led flashing) it wonāt be recognised by the zigbee2mqtt bridge. What can I do to add the wireless switch again to the zigbee2mqtt bridge?
Check the pairing guides (just got updated), maybe you get some tips GitHub - Koenkk/zigbee2mqtt: Zigbee š to MQTT bridge š, get rid of your proprietary Zigbee bridges šØ
[Solved]: turned out that I didnāt have a Xiaomi Aqara wireless switch, but a Xiaomi MiJia wireless switch. They are not the same!
Do you think that this is something that could be supported by the bridge?
they arenāt supported by HA right now. They will pair and show up as the correct sensor but they never trigger an event and then very shortly they disappear from the system and no longer show up in the entities list.
It would be really nice if we someone could get these useable since they are fairly cheap. And many people here already have them since we assumed they would work in HA.
@finity if you have one, you could try it and see what itās produced. A lot of different support seems to be added for harder to pair devices, so I donāt see why this canāt be done.
I donāt have the equipment to build the bridge so I canāt really try it. And Iād rather not spend the money for the equipment unless I have at least some confidence that it will work. Iāve already got lots of little pieces/parts sitting around from failed attempts at a workaround for other devices that wouldnāt ājust workā.
I was hoping someone smarter than me could look at it and give their best educated guess.
I donāt see why it wouldnāt, it supports ZHA 1.2 and also works with smartthings: https://community.smartthings.com/t/bosch-motion-sensor-isw-zpr1-wp13-smartthings-v2-hub/115631/13
In case you have the equipment, feel free to open an issue on github so we can help supporting it.
I have the sensor (actually I have 4 of them just waiting for them to be supported somehow) just not any of the equipment to build the controller bridge.
If you think it will be able to be integrated then I could pull the trigger & order the controller equipment. As I understand it from the wiki all I need are:
CC debugger:
CC2531 Zigbee USB Sniffer:
and a downloader cable:
I already have a spare Raspberry Pi laying around.
I really hope it works. Itās not the $25 wasted that bugs me. Itās my wife nagging me about the growing pile of un-usable stuff laying around that I have to keep trying to justify!
I know. My wife tidied the office yesterday. āYou need to do something about all these wires and bits!ā
I have https://nl.aliexpress.com/item/SmartRF04EB-CC1110-CC2530-ZigBee-Module-USB-Downloader-Emulator/32758806132.html?spm=a2g0s.9042311.0.0.27424c4d01Nfvp that is working.
If you have other sensors or things just sitting around, ping the model list, maybe something else can be put in working condition.
You could maybe take on this offer?
The website says that is no longer available.
Right now all I have in a zigbee āflavorā are 4 of the Bosch motion sensors.
I tested this one as well (links from my orders) and itās working: https://nl.aliexpress.com/item/Free-shipping-SmartRF04EB-CC1110-CC2530-ZigBee-Module-USB-Downloader-Emulator-MCU-NEW/32783177858.html?spm=a2g0s.9042311.0.0.48a94c4dylSqgu
So these are all in one solutions that donāt need a full debugger/cable/sniffer set up?
Iāve ordered a few of these to flash so If youāre interested in one PM me and we can discuss shipping etc and as soon as they arrive to me theyāll be shipped out with custom firmware. I wonāt be taking any payments until I physically receive the devices from China.
Hope this helps some people out!
If anyone from Romania is interested, I am happy to flash for free their CC2531 (Cluj area).
Iām no longer getting state changes for my xiaomi door sensor. I havenāt changed anything since originally setting up the bridge. Any help figuring out the issue would be helpful.
This is the error iām getting.
2018-06-07T18:43:51.551Z - warn: Error while starting zigbee-shepherd, attempting to fix... (takes 60 seconds)
Iāve restarted the pi and now it looks like its connected. However, its not publishing any state changes to HA. I also donāt see any state changes in the log.
2018-6-7 19:11:43 INFO Connected to MQTT server
2018-6-7 19:11:43 INFO MQTT publish, topic: 'zigbee2mqtt/bridge/state', payload: 'online'
2018-6-7 19:11:43 WARN `permit_join` set to `true` in configuration.yaml.
2018-6-7 19:11:43 WARN Allowing new devices to join.
2018-6-7 19:11:43 WARN Set `permit_join` to `false` once you joined all devices.
2018-6-7 19:11:43 INFO Zigbee: allowing new devices to join.
