Very interesting. I currently have a hue hub, xiaomi gateway and my old smartthings hub acting as a mqtt gateway for my TRADFRI bulbs (which are very inconsistent), i was inclined to buy the TRADFRI hub to update the firmware and then pair them to my Hue hub however this might be a better solution.
For me the benefit of this (and deconz) is to move the zigbee integration and device support out of HA code.
By having a docker image/hassio addon it allows easy and āasynchronous to HAā updates.
By using MQTT the solution makes use of very standard, stable and well known HA integration technique.
Thanks, couldnāt describe it better myself!
Have to say Iām planning my HA install at the moment, and moving stuff into MQTT connectors makes a lot of sense. So all external devices go through MQTT leaving HA as the engine, and interaction point.
Nice project @Koenkk,
I am on the same boat as you, and it was after spending quite a sum automating my lights I figured out I could access the state of my switches from outside my home. At that moment I decided I had to get rid of the Xaiomi gateway, because obviously it was communicating with a server which I donāt want.
But a few things please:
Wouldnāt it be easier to just put the hub on like a different network, without access to the internet, so it canāt communicate outside than going all hacking? Considering this option at the moment, as I want to migrate all my automation kit to a different network, giving only HA access to the internet; as I have a spare router at home with openwrt.
Like on the present hub, can one have the battery states of the sensors also? I read how to add support for other devices, so I guess its just a matter of adding āconvertersā to the
lib/converters/zigbee2mqtt.jsfor the battery state? -
What is the coverage like of this solution, and if one has multiple, is it just a matter of using the
configuration.yamlto specify which devices each one should listen to?
Thanks and regards
Im using a fingbox to block all the IoT hubs and devices I have that like to talk to servers outside my network.
Using another VLAN/subnet without routing to internet also works, but I love that fingbox can flip just one hub back āonā to the internet e.g. for firmware update etc.
Thatās a cool kit, but wow it is expensive. Like the cheap stuff
But I think disabling internet access to these devices as you did, is a nice step. Without need of creating more hacks, as sometimes it just makes things a bit messy.
Then you would still have the problem of having multiple hubs (for E.G. Xiaomi, Tradfri) and I would still have to use the Xiaomi app to pair new devices.
Battery state is already supported
You decide with which instance of zigbee2mqtt your want to pair your device with.
I bought it as a funder on indiegogo, so it was cheaper.
For 100% sure that device is not indispensable, but it is nice.
Hopefully HA will get fingbox integration for presence detection.
(Sorry for offtopic discussion
Thanks for the feedback.
Though I have just Xiaomi devices, as they produce all but a single component I need. Nice project and will give it a try.
No worries, nice to see another way to do things every time ![]()
Interested in this thread. Just keeping an eye on it.
Iāve ordered the kit from china (about Ā£16).
Now need to wait a few weeks for it to arriveā¦
Same here, looking forward to it
Starred, Watched and purchased!
Looking forward to this, as in my bedroom i have low reception to my hub, so this will allow me to have a couple of bridges where ever i need them.
Im going to try and run it off of a OrangePi Zero as i have a few in cases lying around.
cheers!
This looks like a great project. Will this work on hassio? If not are you planning an add on at all?
Do you know if the firmware it will work with the CC2540 also:
Any advantages with the CC2540 instead of the CC2531?
That looks like a Bluetooth not zigbee adapter. My guess is it wonāt work.
There is already a multi-arch docker image created by @Koenkk
Creating a hassio addon from that should be pretty easy.
Arhh⦠of course⦠how stupid of me - CC2531 it is thenā¦
I went for the āhigher version numberingā is better approach - but obviously that that wasnāt the caseā¦
