You define a user and password for zigbee2mqtt, but not for mosquitto ?
thanks for the point. I did it for both.
I installed the mosquitto broker new. Now i got an login and i´m a step forward.
thanksâŚ
If you still have the issue - this is what actually helped in my case:
https://www.zigbee2mqtt.io/integration/home_assistant.html
I basically needed to add following into my configuration.yaml
mqtt:
discovery: true
broker: [YOUR MQTT BROKER] # Remove if you want to use builtin-in MQTT broker
birth_message:
topic: 'hass/status'
payload: 'online'
will_message:
payload: 'offline'
And this is the quote from documentation
Zigbee2mqtt is expecting Home Assistant to send itâs birth/will messages to
hass/status
. Be sure to add this to yourconfiguration.yaml
if you want Zigbee2mqtt to resend the cached values when Home Assistant restarts
I have a bunch of Xiaomi wireless switches (these: https://www.zigbee2mqtt.io/devices/WXKG03LM.html) working well with Zigbee2MQTT.
The only âissueâ I have is that as these switches support double press events, and I use them for turning on lights, there is a noticable delay from when I do a single press to the light coming on, caused (in part) by the fact that the switch is waiting to see if I do a double press.
Assuming I donât care about double press functionality, is there anything clever I can do to get around this, i.e. remove the double press functionality, i.e. some sort of firmware mod / hardware mod on the switch, or something I can configure in Zigbee2MQTT / Hassio?
I expect the answer is no but I thought Iâd ask!
Amazing work Koen, your rewritten code did wonders for some of my Aqara sensors, back to life and super stable.
Thank you so much!
Hi.
Iâm looking for help.
I already tried to update few times, but i donât understand what I have to do exactly.
Iâm running Hassio 0.103, zigbee2mqtt is stil at 1.4.0
I would like to update it to 1.7.1, but I canât understand the needed steps.
I know that 1.5.1 introduced breaking changes, and thatâs were I got stuck.
By default, when upgrading to v1.5.1, the add-on will create a backup of your configuration.yml within your data path:
$DATA_PATH/configuration.yaml.bk
no backup is created on my system, but ok, I can save the files manually before updating.
anyway, the configuration.yaml file stored in share/zigbee2mqtt does not change after update.
here is what it contains:
devices:
'0x000d6ffffe688544':
friendly_name: '0x000d6ffffe688544'
retain: false
'0x00124b001938cbb1':
friendly_name: '0x00124b001938cbb1'
retain: false
'0x00158d00029aaf18':
friendly_name: '0x00158d00029aaf18'
retain: false
'0x00158d0002ade3a2':
friendly_name: '0x00158d0002ade3a2'
retain: false
'0x00158d0002e2e527':
friendly_name: '0x00158d0002e2e527'
retain: false
'0x00158d0002ec01a2':
friendly_name: '0x00158d0002ec01a2'
retain: false
'0x00158d00032d2ddc':
friendly_name: '0x00158d00032d2ddc'
retain: false
'0x00158d0003a3f4a4':
friendly_name: '0x00158d0003a3f4a4'
retain: false
'0x7cb03eaa0a049085':
friendly_name: '0x7cb03eaa0a049085'
retain: false
'0x7cb03eaa0a059dc0':
friendly_name: '0x7cb03eaa0a059dc0'
retain: false
'0x7cb03eaa0a05c41a':
friendly_name: '0x7cb03eaa0a05c41a'
retain: false
homeassistant: true
mqtt:
base_topic: zigbee2mqtt
password: mypassword
server: mqtt://homeassistant
user: DVES_USER
permit_join: false
serial:
disable_led: true
port: /dev/ttyACM0
what changes is the config shown in the add-on configuration.
before update:
"data_path": "/share/zigbee2mqtt",
"homeassistant": true,
"permit_join": false,
"mqtt_base_topic": "zigbee2mqtt",
"mqtt_server": "mqtt://homeassistant",
"serial_port": "/dev/ttyACM0",
"devices": [],
"network_key": [],
"mqtt_user": "DVES_USER",
"mqtt_pass": "mypassword",
"disable_led": true
and after update:
"devices": [],
"groups": "groups.yaml",
"mqtt": {
"base_topic": "zigbee2mqtt",
"server": "mqtt://core-mosquitto",
"user": "DVES_USER",
"password": "mypassword"
"serial": {
"port": "/dev/ttyACM0"
"advanced": {
"pan_id": 6754,
"channel": 11,
"network_key": [
1,
3,
5,
7,
9,
11,
13,
15,
0,
2,
4,
6,
8,
10,
12,
13
"availability_blacklist": []
"ban": [],
"whitelist": [],
"queue": {},
"socat": {
"enabled": false,
"master": "pty,raw,echo=0,link=/dev/ttyZ2M,mode=777",
"slave": "tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5",
"restartdelay": 1,
"initialdelay": 1,
"options": "-d -d",
"log": false
"network_key": [],
"disable_led": true
Instructions say:
When upgrading, you should use this to fill in the relevant values into your new config, particularly the network key, to avoid breaking your network and having to repair all of your devices.
But I canât understand what exactly I have to do.
Service does not start and I rolled back to the previous snapshot.
Can anybody please guide me?
Thanks.
Iâm just guessing, but before you had
and now you have
It seems a different mqtt server
Hi.
I already tried to change it, but service does not start anyway.
Then⌠it looks like the old config is appended to the new one.
More, I donât know what to do with the network key.
Thank you for trying to help.
What you could try : save your configuration.yaml somewhere, delete all contents on your RbPi, and then try to start it. There seems to be information in it that has moved to the new JSON.
You mean that maybe it doesnât get updated, so if I remove it, it will create a new one?
Just an empty configuration.yaml on your RbPi, so you are sure it is not something in there that cause the add-on not to start.
Uhm⌠I tried, but the service did not start anyway.
So I tried to delete the redundant part at the bottom of the config:
âmqtt_base_topicâ: âzigbee2mqttâ,
âmqtt_serverâ: âmqtt://homeassistantâ,
âserial_portâ: â/dev/ttyACM0â,
ânetwork_keyâ: ,
âmqtt_userâ: âDVES_USERâ,
âmqtt_passâ: âDomoticA69â,
âdisable_ledâ: true
Then I filled user, password and server in the top part and pressed start.
This time the service started.
Now the empty configuration.yaml has been filled with the new config:
âdata_pathâ: â/share/zigbee2mqttâ,
âdevicesâ: âdevices.yamlâ,
âgroupsâ: âgroups.yamlâ,
âhomeassistantâ: true,
âpermit_joinâ: false,
âmqttâ: {
âbase_topicâ: âzigbee2mqttâ,
âserverâ: âmqtt://homeassistantâ,
âuserâ: âDVES_USERâ,
âpasswordâ: âmypasswordâ
âserialâ: {
âportâ: â/dev/ttyACM0â
âadvancedâ: {
âpan_idâ: 6754,
âchannelâ: 11,
ânetwork_keyâ: [
1,
3,
5,
7,
9,
11,
13,
15,
0,
2,
4,
6,
8,
10,
12,
13
âavailability_blacklistâ:
âbanâ: ,
âwhitelistâ: ,
âqueueâ: {},
âsocatâ: {
âenabledâ: false,
âmasterâ: âpty,raw,echo=0,link=/dev/ttyZ2M,mode=777â,
âslaveâ: âtcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5â,
ârestartdelayâ: 1,
âinitialdelayâ: 1,
âoptionsâ: â-d -dâ,
âlogâ: false
My zigbee entities are there, but they look not responding.
In the log I can see that only 2 of them (cc2531 router and an Aqara button) are working. The others are marked as not existing:
zigbee2mqtt:info 2019-12-12T15:16:18: Logging to directory: â/share/zigbee2mqtt/log/2019-12-12.16-16-17â
zigbee2mqtt:info 2019-12-12T15:16:18: Starting zigbee2mqtt version 1.7.1 (commit #unknown)
zigbee2mqtt:info 2019-12-12T15:16:18: Starting zigbee-herdsmanâŚ
zigbee2mqtt:info 2019-12-12T15:16:20: zigbee-herdsman started
zigbee2mqtt:info 2019-12-12T15:16:20: Coordinator firmware version: â{âtypeâ:âzStack12â,âmetaâ:{âtransportrevâ:2,âproductâ:0,âmajorrelâ:2,âminorrelâ:6,âmaintrelâ:3,ârevisionâ:20190608}}â
zigbee2mqtt:info 2019-12-12T15:16:20: Currently 11 devices are joined:
zigbee2mqtt:info 2019-12-12T15:16:20: 0x000d6ffffe688544 (0x000d6ffffe688544): LED1624G9 - IKEA TRADFRI LED bulb E14/E26/E27 600 lumen, dimmable, color, opal white (Router)
zigbee2mqtt:info 2019-12-12T15:16:20: 0x00158d00032d2ddc (0x00158d00032d2ddc): ZNLDP12LM - Xiaomi Aqara smart LED bulb (Router)
zigbee2mqtt:info 2019-12-12T15:16:20: 0x00158d0002ade3a2 (0x00158d0002ade3a2): WXKG12LM - Xiaomi Aqara wireless switch (with gyroscope) (EndDevice)
zigbee2mqtt:info 2019-12-12T15:16:20: 0x7cb03eaa0a049085 (0x7cb03eaa0a049085): AC03641 - OSRAM LIGHTIFY LED Classic A60 clear (Router)
zigbee2mqtt:info 2019-12-12T15:16:20: 0x00124b001938cbb1 (0x00124b001938cbb1): CC2530.ROUTER - Custom devices (DiY) CC2530 router (Router)
zigbee2mqtt:info 2019-12-12T15:16:20: 0x00158d0002e2e527 (0x00158d0002e2e527): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
zigbee2mqtt:info 2019-12-12T15:16:20: 0x00158d0002ec01a2 (0x00158d0002ec01a2): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
zigbee2mqtt:info 2019-12-12T15:16:20: 0x00158d00029aaf18 (0x00158d00029aaf18): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
zigbee2mqtt:info 2019-12-12T15:16:20: 0x7cb03eaa0a05c41a (0x7cb03eaa0a05c41a): AC03641 - OSRAM LIGHTIFY LED Classic A60 clear (Router)
zigbee2mqtt:info 2019-12-12T15:16:20: 0x7cb03eaa0a059dc0 (0x7cb03eaa0a059dc0): AC03641 - OSRAM LIGHTIFY LED Classic A60 clear (Router)
zigbee2mqtt:info 2019-12-12T15:16:20: 0x00158d0003a3f4a4 (0x00158d0003a3f4a4): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (EndDevice)
zigbee2mqtt:info 2019-12-12T15:16:20: Zigbee: disabling joining new devices.
zigbee2mqtt:info 2019-12-12T15:16:20: Connecting to MQTT server at mqtt://homeassistant
zigbee2mqtt:info 2019-12-12T15:16:21: Connected to MQTT server
zigbee2mqtt:info 2019-12-12T15:16:21: MQTT publish: topic âzigbee2mqtt/bridge/stateâ, payload âonlineâ
zigbee2mqtt:error 2019-12-12T15:16:21: â0x000d6ffffe688544â does not exist, skipping publish
zigbee2mqtt:error 2019-12-12T15:16:21: â0x00158d00032d2ddcâ does not exist, skipping publish
zigbee2mqtt:info 2019-12-12T15:16:21: MQTT publish: topic âzigbee2mqtt/0x00158d0002ade3a2â, payload â{âlinkqualityâ:99,âbatteryâ:97,âvoltageâ:2995}â
zigbee2mqtt:error 2019-12-12T15:16:21: â0x7cb03eaa0a049085â does not exist, skipping publish
zigbee2mqtt:info 2019-12-12T15:16:21: MQTT publish: topic âzigbee2mqtt/0x00124b001938cbb1â, payload â{âstateâ:true,âlinkqualityâ:0,âled_stateâ:false}â
zigbee2mqtt:error 2019-12-12T15:16:21: â0x00158d0002e2e527â does not exist, skipping publish
zigbee2mqtt:error 2019-12-12T15:16:21: â0x00158d0002ec01a2â does not exist, skipping publish
zigbee2mqtt:error 2019-12-12T15:16:21: â0x00158d00029aaf18â does not exist, skipping publish
zigbee2mqtt:error 2019-12-12T15:16:21: â0x7cb03eaa0a05c41aâ does not exist, skipping publish
zigbee2mqtt:error 2019-12-12T15:16:21: â0x7cb03eaa0a059dc0â does not exist, skipping publish
zigbee2mqtt:error 2019-12-12T15:16:21: â0x00158d0003a3f4a4â does not exist, skipping publish
Probably itâs here that the network key must be fixed, but I donât know how.
If 2 of them are working, the key is fine. Just set permit_join to true and normally the others should reconnect themselves.
I did something different, I noticed that devices.yaml and groups.yaml files have been created in zigbee2mqtt folder.
I opened devices.yaml and i saw that the 2 working devices were in there!
So I just copied the others from the old configuration.yaml and now they are ok.
I hope that no more suprises are waiting
Thank you very much.
Excellent will give this a go.Thank you.
Does anyone know what the default channel the co-ordinator runs on?
Thanks. Same channel at my Wi-Fi but I learned that itâs actually not the same and if they are both in 11 that means Iâm getting the least amount of interference⌠I think I need a repeater
Mmmm⌠after upgrading to 1.7.1, led on coordinator stays on.
I checked the config and noticed that the line âdisable_led: trueâ was missing in serial: section.
I added it, but it aumatically deletes it again. I put it in configuration.yaml: deleted.
I stopped service, added the line, started the service and⌠it was removed from the config again.
Is there a way to turn off again that led?
My z2m add-on (version 1.7.0) has now a config with
"serial": {
"disable_led": "true",
⌠and the light is off. So perhaps you could try this.
