Zigbee2Mqtt gives me 502: Bad Gateway
I’ve got a CC2531 chip that I flashed with the correct firmware and it’s tuning on and in the zigbee2mqtt logs I can see that it finds it. Before I had flashed the CC2531 chip Zigbee2Mqtt gave me error so I assume the chip is working fine.
When I try to open the Zigbee2Mqtt interface I get a 502: Bad Gateway and in the supervisor log I get this message:
21-10-21 11:05:39 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.33.5:8099 ssl:default [Connect call failed ('172.30.33.5', 8099)]
Zigbee2mqtt
Current version: 1.21.2-1
data_path: /config/zigbee2mqtt
external_converters: []
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: false
mqtt:
  base_topic: zigbee2mqtt
  server: mqtt://localhost:1883
  user: mqtt
  password: xxxxx
serial:
  port: /dev/ttyACM0
advanced:
  log_level: warn
  pan_id: 6754
  channel: 11
  network_key:
    - 1
    - 3
    - 5
    - 7
    - 9
    - 11
    - 13
    - 15
    - 0
    - 2
    - 4
    - 6
    - 8
    - 10
    - 12
    - 13
  availability_blocklist: []
  availability_passlist: []
device_options: {}
blocklist: []
passlist: []
queue: {}
frontend:
  port: 8099
experimental: {}
socat:
  enabled: false
  master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
  slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
  options: '-d -d'
  log: false
What does the Zigbee2MQTT log say ?
According to that screenshot, Zigbee2MQTT is not fully started yet. So wait a little bit before you try again.
I’ts been like this for a whole day…
I guess something in the actual addon is broken?
There definitely should be more text after
> [email protected] start
> node index.js
You haven’t added everything in your configuration to enable the frontend.
Read the documentation tab in the addon it has what you need to copy into your configuration.
if you’re referring to I’ve already done that…
frontend:
 port: 8099
experimental:
 new_api: true
I get this:
21-10-21 13:11:21 WARNING (MainThread) [supervisor.addons.options] Unknown option 'new_api' for Zigbee2mqtt (45df7312_zigbee2mqtt)
Yes, the documentation on the add-on is wrong.
experimental:
 new_api: true
has been removed a log time ago.
Yeah… so is there something else I should do instead of “new_api: true”?
Your config seems fine, it just seems Zigbee2MQTT does not start fully as it never gets beyond
> node index.js
and I don’t have an idea why.
Hmm alright :frowning:
Do you have an idea why I get this when I try to open the Zigbee2Mqtt UI?
21-10-21 13:57:31 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.33.5:8099 ssl:default [Connect call failed ('172.30.33.5', 8099)]
21-10-21 13:59:22 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.33.5:8099 ssl:default [Connect call failed ('172.30.33.5', 8099)]
Yes, Zigbee2MQTT is not yet started fully, so the webinterface is not running.
Alright… running netstat I get this:
is the 172.30.33.2 a local IP?
btw I should’ve mentioned this in the start. I’m running my home-assitant through duckdns.org and opened the port 443. Maybe this has anything to do with the Zigbee2MQTT?
Setting permit_join gives me these log, does this indicate that it’s running? (Still getting Bad gateway…)
Yes, seems to be running
Try (without ingress) http://ip-of-ha:8099 and see if you get something.
Getting ERR_CONNECTION_REFUSED
And the same with https://ip-of-ha:8099 ?
oh, I see someone clicked the link http://ip-of-ha:8099 in my previous post. Be sure to replace ip-of-ha with the ip-address of your home assistant instance.
Yes same result. And yeah hahaha I accidentally clicked the link…
Is there any other zigbee2mqtt alternative I can try?
