Zigbee2mqtt grouping not working
I recently discovered z2m grouping for my lights.
Until now, I was grouping my lights from HA UI, but it appeared that my coordinator (conbee 2) was not able to send all the messages individually to all my devices (25+).
I then started to group devices through zigbee2mqtt directly, which would theoretically allow me to send a on / off command to the newly created entity in HA once.
The thing is that I have a very strange behavior…
When I switch the lights on and off, through HA, the order appears to be sent and zigbee2mqtt and HA display a new state for all the entities in the group.
IE : I switch the lights group to ON, all the lights appear to be ON in HA AND Z2M.
The problem is that they DON’T actually switch on and off : they remain in their previous state.
The only thing I can do is to individually put my lights in their correct states so I can switch them on and off again…
To be very accurate, this does not appear to be a problem of switch numbers : whatever is the number of devices in the group (3 or 25), the problem remains.
This behavior is very strange, what’s your point of view ?
Thanks in advance.
No one got the same issue ? :frowning:
Bumping a ‘dead’ thread, but yeah its like 50/50 imo, sometimes my z2m groups work and sometimes it doesnt, I got so fed up with my z2m groups being so inconsistent that i bit the bullet and abandoned it and instead use HA-groups, even though that clogs up the zigbee-network/traffic
