Zigbee2MQTT has been failing randomly recently, why?
Everythings working, then go to press a zigbee switch and nothing happens. Check Zigbee2MQTT logs and see log below. Sometimes just starting it again gets it back up, other times I need to unplug and plug device back into my Home Assistant Blue hardware.
Looks like a cabling or dongle issue going on that error.
I assume you are using an extension cable as recommended. Try another cable.
