Any suggestions, please?
zigbee2mqtt was behaving very well until recently. Then, various devices started disappearing and, finally, it seems that the add-on cannot find the CC2531 stick.
I had auto update on (won’t do that again) while traveling a lot, so I’m not sure when/ with which versions the problems really started.
I have tried reflashing the CC2531 firmware with CC2531_DEFAULT_20190608 and uninstalling/reinstalling the add on. I have also rebooted the host system, resetting the stick, restarting HA, etc., many times.
HA Hassio 102.1
zigbee2mqtt add-on 1.7.1
Host system info
root@homeauto:~# dmesg | grep tty
[ 0.000000] console [tty0] enabled
[ 92.074357] usb 1-3: FTDI USB Serial Device converter now attached to ttyUSB0
[ 1255.121788] cdc_acm 1-2:1.0: ttyACM0: USB ACM device
root@homeauto:~# ls -l /dev/serial/by-id
total 0
lrwxrwxrwx 1 root root 13 Nov 23 16:17 usb-RFXCOM_RFXtrx433_A11I9D34-if00-port0 -> ../../ttyUSB0
lrwxrwxrwx 1 root root 13 Nov 23 16:17 usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B00193695D0-if00 -> ../../ttyACM0
config
"data_path": "/share/zigbee2mqtt",
"devices": "devices.yaml",
"groups": "groups.yaml",
"homeassistant": true,
"permit_join": false,
"mqtt": {
"base_topic": "zigbee2mqtt",
"server": "mqtt://192.168.86.111:8883",
"user": "xxxx",
"password": "xxxx"
"serial": {
"port": "ttyACM0"
"advanced": {
"pan_id": 6754,
"channel": 11,
"network_key": [
2,
59,
56,
29,
34,
35,
74,
67,
90,
9,
45,
62,
74,
65,
8,
34
"availability_blacklist": []
"ban": [],
"whitelist": [],
"queue": {},
"socat": {
"enabled": false,
"master": "pty,raw,echo=0,link=/dev/ttyZ2M,mode=777",
"slave": "tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5",
"restartdelay": 1,
"initialdelay": 1,
"options": "-d -d",
"log": false
log
./run.sh: line 16: [Info] Configuration backup found in /share/zigbee2mqtt/.configuration.yaml.bk. Skipping config backup.: No such file or directory
[Info] Socat is DISABLED and not started
2019-11-23T16:25:24: PM2 log: Launching in no daemon mode
2019-11-23T16:25:24: PM2 log: App [npm:0] starting in -fork mode-
2019-11-23T16:25:24: PM2 log: App [npm:0] online
> [email protected] start /zigbee2mqtt-1.7.1
> node index.js
zigbee2mqtt:info 2019-11-23T16:25:25: Logging to directory: '/share/zigbee2mqtt/log/2019-11-23.16-25-24'
zigbee2mqtt:info 2019-11-23T16:25:25: Starting zigbee2mqtt version 1.7.1 (commit #unknown)
zigbee2mqtt:info 2019-11-23T16:25:25: Starting zigbee-herdsman...
zigbee2mqtt:error 2019-11-23T16:25:25: Error while starting zigbee-herdsman
zigbee2mqtt:error 2019-11-23T16:25:25: Failed to start zigbee
zigbee2mqtt:error 2019-11-23T16:25:25: Exiting...
zigbee2mqtt:error 2019-11-23T16:25:25: Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open ttyACM0'
at Znp.<anonymous> (/zigbee2mqtt-1.7.1/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:109:32)
at Generator.next (<anonymous>)
at /zigbee2mqtt-1.7.1/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:8:71
at new Promise (<anonymous>)
at __awaiter (/zigbee2mqtt-1.7.1/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:4:12)
at SerialPort.serialPort.open (/zigbee2mqtt-1.7.1/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:107:49)
at SerialPort._error (/zigbee2mqtt-1.7.1/node_modules/zigbee-herdsman/node_modules/@serialport/stream/stream.js:197:14)
at binding.open.then.err (/zigbee2mqtt-1.7.1/node_modules/zigbee-herdsman/node_modules/@serialport/stream/stream.js:241:12)
npm ERR!
code ELIFECYCLE
npm ERR! errno 1
npm ERR!
[email protected] start: `node index.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] start script.
npm
ERR! This is probably not a problem with npm. There is likely additional logging output above.
Hassio “Hardware” report
Hardware
serial:
/dev/ttyS13
/dev/ttyS12
/dev/ttyS4
/dev/ttyS1
/dev/ttyS28
/dev/ttyS6
/dev/ttyS27
/dev/ttyS21
/dev/ttyACM0
/dev/ttyS7
/dev/ttyS30
/dev/serial/by-id/usb-RFXCOM_RFXtrx433_A11I9D34-if00-port0
/dev/ttyS11
/dev/ttyS26
/dev/ttyS20
/dev/ttyS25
/dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B00193695D0-if00
/dev/ttyS22
/dev/ttyS2
/dev/ttyS23
/dev/ttyUSB0
/dev/ttyS18
/dev/ttyS16
/dev/ttyS14
/dev/ttyS17
/dev/ttyS10
/dev/ttyS15
/dev/ttyS3
/dev/ttyS31
/dev/ttyS24
/dev/ttyS9
/dev/ttyS8
/dev/ttyS5
/dev/ttyS29
/dev/ttyS19
/dev/ttyS0
input:
HDA Intel PCH HDMI/DP,pcm=8
HDA Intel PCH HDMI/DP,pcm=3
HDA Intel PCH Front Headphone
Power Button
HDA Intel PCH HDMI/DP,pcm=9
HDA Intel PCH Mic
Video Bus
Sleep Button
HDA Intel PCH HDMI/DP,pcm=10
HDA Intel PCH HDMI/DP,pcm=7
disk:
gpio:
gpiochip200
audio:
