Zigbee2mqtt help needed
I get the following in my log file
[13:10:37] INFO: Preparing to start...
[13:10:38] INFO: Socat not enabled
[13:10:40] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info  2024-02-25 13:10:46: Logging to console and directory: '/config/zigbee2mqtt/log/2024-02-25.13-10-45' filename: log.txt
Zigbee2MQTT:info  2024-02-25 13:10:46: Starting Zigbee2MQTT version 1.35.3 (commit #unknown)
Zigbee2MQTT:info  2024-02-25 13:10:46: Starting zigbee-herdsman (0.33.8)
Zigbee2MQTT:error 2024-02-25 13:11:06: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2024-02-25 13:11:06: Failed to start zigbee
Zigbee2MQTT:error 2024-02-25 13:11:06: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2024-02-25 13:11:06: Exiting...
Zigbee2MQTT:error 2024-02-25 13:11:06: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
    at ZStackAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:103:27)
    at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:132:29)
    at Zigbee.start (/app/lib/zigbee.ts:60:27)
    at Controller.start (/app/lib/controller.ts:109:27)
    at start (/app/index.js:107:5)
This is the configuration
data_path: /config/zigbee2mqtt
socat:
  enabled: false
  master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
  slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
  options: "-d -d"
  log: false
mqtt:
  server: mqtt://core-mosquitto:1883
  user: mqtt
  password: mqtt
serial:
  port: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
  adaper: ezsp
Please help
Looks to me like your serial port is set wrong.
I set it like
port: /dev/ttyUSB0
But still the same result
What adapter do you have ?
Zigbee 3.0 USB Dongle Based on Silicon Labs EFR32MG21 Universal Zigbee Gateway ZB-GW04 Adapter
I saw the error already, it is adapter: , not adaper:
socat:
  enabled: false
  options: "-d -d"
  log: false
mqtt:
  user: mqtt
  password: mqtt
serial:
  adapter: ezsp
