Zigbee2mqtt, if I replace the CC2530 or CC1352-P2 with an identical
Running zigbee2mqtt with a CC1352-P2 as coordinator. I suspect there is a hw fault in my device and have a brand new one available. Can I simply replace the running one with the new one, or do I have to re-pair all my sensors?
I’ve swapped my CC2531/CC2530 many times without repairing.
I think your safe.
I switched between CC1352-P2’s without any problem. No need for repairing.
Hi @nanobra1n
I tried to simply replace my CC1352-P2 today followed by a reboot of hassio. It did not connect to any of my zigbee devices on restart.
Do I have to edit something in the configuration.yaml for zigbee2mqtt when I replace the CC ?
What was the original z2m adapter ? It can be difficult if you replace a CC2530 or CC2531 with a CC1352-P2. You have to look in the log what the problem is.
The original is also a CC1352-P2
Running Z2M as standalone docker on a NUC.
The reason for replacing is that I suspect the soldering for switching to external antenna was not successful so I wanted to swap the original CC1352-P2 with a brand new one (of course, flashed with the correct firmware) to compare link quality.
Normally you don’t have to repair.
If you used something like this in your configuration.yaml (the one of zigee2mqtt)
serial:
  port: >-
    /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001949EE9C-if00
The port will have changed.
My port config is simply:
serial:
  port: /dev/ttyACM0
As @francisp suggested, make sure that the port didn’t change. Using the /dev/serial/by-id/ path is a good idea because it won’t change through reboots. Note that you will want the .. if00 name. I also found that the first time I started a new CC1352 z2m was spewing error messages for a while. After a few minutes they went away and z2m connected to the coordinator. No repairing was necessary.
What do you use for port config ?
I got two devices when I run ls -l /dev/serial/by-id t
lrwxrwxrwx 1 root root 13 Mar  6 11:17 usb-Texas_Instruments_XDS110__03.00.00.05__Embed_with_CMSIS-DAP_L4300170-if00 -> ../../ttyACM0
lrwxrwxrwx 1 root root 13 Mar  6 11:17 usb-Texas_Instruments_XDS110__03.00.00.05__Embed_with_CMSIS-DAP_L4300170-if03 -> ../../ttyACM1
Why do I have it on both ACM0 and ACM1 ? I only have one device currently connected and my configurattion.yaml points to /dev/ttyACM0
You want the one that ends in if00.
Without trying yet, are they unique, meaning when I swap the CC1352 it will change ?
Or is this the ‘solution’ so the adapters can be changeable without any editing, just unplug and replug?
The /dev/serial/by-id name will be unique to the CC1352. But regardless what value for port you use, the log content should give you an idea what is going wrong.
