Zigbee2mqtt ikea E2123 blueprint for generic use
Importing Blueprints into Home Assistant
If you see this import badge, click it:
To import a Blueprint manually:
  • Visit the topic of the blueprint that you want to import
  • Copy the URL from the browser address bar
  • Go to Home Assistant → Configuration → Automations & Scenes → Blueprints and click on “Import Blueprint” button in the bottom right.
  • Paste the blueprint topic URL and click on “Preview Blueprint”
  • Click on “Import Blueprint”
I can install the blueprint but the actions do not trigger.
Is it intended for the latest release Gen2 (20230308) ?
The remote actions work when I create my own automations.
there was an error. I should have solved the problem
Thanks, just tested, problem solved.
Cheers.
