zigbee2MQTT Instability
Zigbee2MQTT and ember is simply broken… You are not the only one.
Time to move to ZHA?
To try to stabilise
I have moved zigbee2MQTT to a factory fresh Home Assistant green to only do zigbee2MQTT
I have moved to an Ethernet Poe smlight Zigbee coordinator to ensure I can place it in the optimal location for a house wide zigbee.
I have optimised WiFi and zigbee,
Hue on channel 25
zigbee2MQTT on 11
Wi-Fi channels 6 & 11
Struggling to keep zigbee2MQTT up and running without playing the offline wackomole
I also had to reset most of the devices. Remove them completely and reconnect. A bit of struggle to get to some of those…
Well…. Not holding my breath, but all of a sudden zigbee2MQTT has been solid for the last 5 hours with only 2 devices dropping offline.
Error messages dropped to one every couple hours down from the constant deluge.
Fingers crossed
