I installed mosquito broker and Zigbee2Mqtt, configured the coordinator adrress and y get this errors every time I try to iniciate it.
I’ve read this page https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html but I cant find how to fix my error.
[11:02:07] INFO: Preparing to start...
[11:02:07] INFO: Socat not enabled
[11:02:07] INFO: Starting Zigbee2MQTT...
Starting Zigbee2MQTT without watchdog.
[2024-11-27 11:02:09] info: z2m: Logging to console, file (filename: log.log)
[2024-11-27 11:02:09] info: z2m: Starting Zigbee2MQTT version 1.41.0 (commit #unknown)
[2024-11-27 11:02:09] info: z2m: Starting zigbee-herdsman (2.1.7)
[2024-11-27 11:02:09] info: zh:zstack:znp: Opening SerialPort with {"path":"/dev/ttyUSB0","baudRate":115200,"rtscts":false,"autoOpen":false}
[2024-11-27 11:02:09] info: zh:zstack:znp: Serialport opened
[2024-11-27 11:02:10] info: zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2024-11-27 11:02:11] info: zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2024-11-27 11:02:29] error: z2m: Error while starting zigbee-herdsman
[2024-11-27 11:02:29] error: z2m: Failed to start zigbee
[2024-11-27 11:02:29] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-11-27 11:02:29] error: z2m: Exiting...
[2024-11-27 11:02:30] error: z2m: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
at ZStackAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:113:27)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:137:29)
at Zigbee.start (/app/lib/zigbee.ts:69:27)
at Controller.start (/app/lib/controller.ts:161:27)
at start (/app/index.js:154:5)
