Zigbee2mqtt integration problem
Orange PI 4 LTS with Debian GNU/Linux 11 (bullseye)
Home Assistant 2023.1.6
Supervisor 2023.01.dev1301
Mosquitto broker 6.1.3
Zigbee2MQTT 1.29.2-1
Config (zigbee2mqtt):
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: “-d -d”
log: false
base_topic: zigbee2mqtt
server: mqtt://core-mosquitto
port: /dev/serial/by-path/platform-fe3a0000.usb-usb-0:1:1.0-port0
(also tested with /dev/ttyUSB0)
I got this:
Error: network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby
I changed pan_id, ext_pan_id and channel - always got the same. I reflashed my Sonoff dongle on Windows with last firmware - same result. Any help?
Log:
[12:15:07] INFO: Preparing to start...
[12:15:07] INFO: Socat not enabled
[12:15:09] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info 2023-01-15 12:15:13: Logging to console and directory: '/config/zigbee2mqtt/log/2023-01-15.12-15-13' filename: log.txt
Zigbee2MQTT:info 2023-01-15 12:15:13: Starting Zigbee2MQTT version 1.29.2 (commit #unknown)
Zigbee2MQTT:info 2023-01-15 12:15:13: Starting zigbee-herdsman (0.14.83-hotfix.0)
Zigbee2MQTT:error 2023-01-15 12:16:19: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2023-01-15 12:16:19: Failed to start zigbee
Zigbee2MQTT:error 2023-01-15 12:16:19: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2023-01-15 12:16:19: Exiting...
Zigbee2MQTT:error 2023-01-15 12:16:20: Error: network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby
at ZnpAdapterManager.beginCommissioning (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:347:23)
at ZnpAdapterManager.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:92:17)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:132:29)
at Zigbee.start (/app/lib/zigbee.ts:58:27)
at Controller.start (/app/lib/controller.ts:101:27)
at start (/app/index.js:107:5)
The same hw setup and HA works well with ZHA integration. Also Homebridge on this stuff and zigbee2mqtt is OK. Any idea what to do/try next to integrate zigbee2mqtt with latest HA?
Same problem here, SOLVED using this hint: CC2652RB Error Network Commissioning Timeout (panID or extendedPanID already exists nearby) · Issue #10858 · Koenkk/zigbee2mqtt · GitHub
