Hi there, I’m having some issues with my Zigbee devices staying connected. I recently reconnected all of my devices due to some issues with the Addon itself. After the setup the zigbee map was showing pretty good connection (>140 lqi). Now the devices suddenly lost on connection quality and some devices aren’t even showing being connected.
Battery devices tend to do that. Are they not reporting anything? Try breathing on a temperature sensor for example.
This is how Sonoff SNZB-01 behaves in my settings, but despite, they works.
They are reporting I think, but sometimes I feel like they just don’t report. For example my thermostat valves sometimes show current temperature as 23°C but the heating is set to 20°C and despite that they still send Heat signal. I don’t know if it’s the thermostat issue or Home Assistant issue
Your screenshot shows it’s set to 20 and reporting 20. As long as the devices report from time to time you are good, this is expected from battery devices.
