Zigbee2mqtt - (Lidl) Silvercrest Livarno Lux switch and dimming light remote control
This builds on the work of starbuck93 getting the Ikea 5 button remote to work with Z2M.
This blueprint allows the use of the light dimmer remote sold by Lidl with their starter smart light pack. The remote must be paired and working with zigbee2mqtt. Model number FB20-002/HG06323.
On/off works as expected. Brightness can be pressed once or held down to smoothly dim. Alternatively long pressing the brightness buttons can be used to trigger different actions.
For the remote to select, it should be in the format sensor.friendly_remote_name_action. It uses the sensor created by z2m.
blueprint:
  name: Z2M - (Lidl) Silvercrest Livarno Lux switch and dimming light remote control
  description: |
    Control lights with the Silvercrest Livarno remote sold by Lidl connected through zigbee2mqtt. Model number FB20-002/HG06323
    The on/off buttons work as expected to change the configured light entities. You can additonally specify the brightness to use when turning on.
    Brightness up/down will work with single click, or smoothly dim them if held down.
    Alternatively, different actions can be specified on long press of the brightness buttons.
    This blueprint is based on the great work by starbuck93 here: https://community.home-assistant.io/t/zigbee2mqtt-ikea-five-button-remote/255308
  domain: automation
  input:
    remote:
      description: Remote to use
      selector:
        entity:
          integration: mqtt
          domain: sensor
    light:
      description: The light(s) to control
      selector:
          entity:
            domain: light
    force_brightness:
      name: Force turn on brightness
      description: >
        Force the brightness to the set level below, when the "on" button on
        the remote is pushed and lights turn on.
      default: false
      selector:
        boolean:
    brightness:
      description: Brightness of the light(s) when turning on
      default: 50
      selector:
        number:
          min: 0
          max: 100
          mode: slider
          step: 1
          unit_of_measurement: "%"
    alt_brightness_up_hold:
      name: Run action on brightness up hold
      description: >
        Configure a different action to run when holding brightness up instead of increasing light brightness.
      default: false
      selector:
        boolean:
    button_brightness_up_hold:
      name: Brightness up hold
      description: Action to run on brightness up hold
      default: []
      selector:
    alt_brightness_down_hold:
      name: Run action on brightness down hold
      description: >
        Configure a different action to run when holding brightness down instead of decreasing light brightness.
      default: false
      selector:
        boolean:
    button_brightness_down_hold:
      name: Brightness down hold
      description: Action to run on brightness down hold
      default: []
      selector:
mode: restart
max_exceeded: silent
variables:
  force_brightness: !input force_brightness
  alt_brightness_up_hold: !input alt_brightness_up_hold
  alt_brightness_down_hold: !input alt_brightness_down_hold
  - platform: state
    entity_id: !input remote
    attribute: action
  - variables:
      command: "{{ trigger.to_state.state }}"
  - choose:
      - conditions:
          - "{{ command == 'on' }}"
        sequence:
          - choose:
              - conditions: "{{ force_brightness }}"
                sequence:
                  - service: light.turn_on
                    target: !input light
                      transition: 1
                      brightness_pct: !input brightness
            default:
                  transition: 1
      - conditions:
          - "{{ command == 'off' }}"
        sequence:
          - service: light.turn_off
              transition: 1
      - conditions:
          - "{{ command == 'brightness_step_up' }}"
        sequence:
              brightness_step_pct: 10
              transition: 1
      - conditions:
          - "{{ command == 'brightness_move_up' }}"
        sequence:
          - choose:
              - conditions: "{{ alt_brightness_up_hold }}"
                sequence: !input button_brightness_up_hold
            default:
              - repeat:
                  until:
                    - condition: state
                      state: brightness_stop
                      attribute: action
                  sequence:
                        transition: 1
                    - delay: "1"
      - conditions:
          - "{{ command == 'brightness_step_down' }}"
        sequence:
              brightness_step_pct: -10
              transition: 1
      - conditions:
          - "{{ command == 'brightness_move_down' }}"
        sequence:
          - choose:
              - conditions: "{{ alt_brightness_down_hold }}"
                sequence: !input button_brightness_down_hold
            default:
              - repeat:
                  until:
                    - condition: state
                      attribute: action
                  sequence:
                        transition: 1
                    - delay: "1"
That blueprint looks very interesting, but I’ve some problems.
I created this yaml file, but when I want create the automation based on this blueprint I can’t choose in “Remote to use” field right entity of the Lidl remote control. I’ve added this device by Conbee II and I have only entity related to the power status of the remote control.
Are you using zigbee2mqtt?
Actually I’ve already found that it is need for zigbee2mqtt. I am beginner with HASS ;)) Do you have any link which help me to set it up after connection in ZHA via Conbee?
Unfortunately only tested with z2m. It provides a sensor with the button clicked on the remote. Not sure how it works on ZHA.
I tested it on zigbee2mqtt. Everything works fine!
Hello together. My question is only semi-related. Has anyone an idea where I can get this remote(s) separately. Found one in the LIDL Home starter kit and it would solve some of my problems I have at home.
I contacted owim and optimex (it seems that they produce or at least provide the products for LIDL) but till now I had no fortune with it.
Thanks.
Not worth getting it separately. Get the Philips Hue dimmer instead. It has the same features, but it can do different actions on long presses for all buttons.
Well, it does excactly what I need. Switch on/off and dimm. Plus it easily works with Lidl smart home as it is made for it and fully integrated. I just received an OSRAM/LEDVANCE smart+ mini switch. I will check if it is possible to connect it with the the Lidl Smart Home system.
Actually I got the Philips Hue dimmer switch after I tried the LEDVANCE Switch and wasn’t able to connect it with my LIDL Gateway. It didn’t work either. So, I’m still looking for the LIDL remote :frowning: So if anyone has two left over I’m willing to buy them.
Sorry I didn’t catch that you were using the gateway. This was for using a separate dongle, so it works with devices across brands.
I know this is quite a old topic but im facing an issue with this blueprint; its not repeating the brightness steps:
I’ve got the the lagacy properties set to true
Home Assistant legacy entity attributes
Home Assistant legacy triggers
When I set a manual action on the brightness_move_down action, and let it repeat for x times it does also not work, the repeat step only gets executed once and the automatisation is then finished.
I just deleted my remote and configured it again, now it is working as it should. I guess I broke some setting in HA / Z2M.
Hello, since Z2MQTT has been updated to 2.0 the sensor is no longer recognized. Any help ?
Enable legacy action entities in the Z2M UI.
Under :gear: find the Home Assistant section and check the enable legacy action entities.
That should get you going until the deprecation period ends.
I would be looking at taking control of this blueprint in your home and fixing this.
There are a myriad of other posts this week that explain more.
Hi there,
I’ve changed the blueprint to meet the new action-events that was implemented in the new zigbee2mqtt 2.0.0+ versions. For those who want to migrate as well, please c/p the script below.
blueprint:
  name: Z2M version 2 - (Lidl) Silvercrest Livarno Lux switch and dimming light remote control
  description: 'Control lights with the Silvercrest Livarno remote sold by Lidl connected
    Version complient to zigbee2mqtt 2.0.0+
    buttons.
  domain: automation
  input:
    remote:
      selector:
        entity:
          integration: mqtt
          domain:
          - event
          multiple: false
    light:
      selector:
          entity:
          - domain:
            - light
    force_brightness:
      description: 'Force the brightness to the set level below, when the "on" button
        on the remote is pushed and lights turn on.
      default: false
      selector:
        boolean: {}
    brightness:
      default: 50
      selector:
        number:
          min: 0.0
          max: 100.0
          mode: slider
          step: 1.0
          unit_of_measurement: '%'
      description: 'Configure a different action to run when holding brightness up
      default: false
      selector:
        boolean: {}
      default: []
      selector:
        action: {}
      description: 'Configure a different action to run when holding brightness down
      default: false
      selector:
        boolean: {}
      default: []
      selector:
        action: {}
  source_url: https://community.home-assistant.io/t/zigbee2mqtt-lidl-silvercrest-livarno-lux-switch-and-dimming-light-remote-control/260323
mode: restart
variables:
triggers:
- trigger: state
  attribute: event_type
- variables:
    command: '{{ trigger.to_state.attributes.event_type }}'
- choose:
  - conditions:
    - '{{ command == ''on'' }}'
    sequence:
    - choose:
      - conditions: '{{ force_brightness }}'
        sequence:
            transition: 1
      default:
          transition: 1
  - conditions:
    - '{{ command == ''off'' }}'
    sequence:
        transition: 1
  - conditions:
    - '{{ command == ''brightness_step_up'' }}'
    sequence:
        transition: 1
  - conditions:
    - '{{ command == ''brightness_move_up'' }}'
    sequence:
    - choose:
      - conditions: '{{ alt_brightness_up_hold }}'
      default:
      - repeat:
          until:
          - condition: state
          sequence:
              transition: 1
          - delay: '1'
  - conditions:
    - '{{ command == ''brightness_step_down'' }}'
    sequence:
        transition: 1
  - conditions:
    - '{{ command == ''brightness_move_down'' }}'
    sequence:
    - choose:
      - conditions: '{{ alt_brightness_down_hold }}'
      default:
      - repeat:
          until:
          - condition: state
          sequence:
              transition: 1
          - delay: '1'
Hi @WollyWonka,
I tried using that script but I failed making it work :frowning:
The remote is not recognized by the automation and using the previous format “sensor.friendly_remote_name_action” doesn’t work either.
What am I doing wrong ?
The actions are correctly seen at z2m level.
Thanks!
I’ve updated the Blueprint to work with Zigbee2MQTT 2. Haven’t yet tested the Up/Down hold part.
blueprint:
  name: Z2M 2.0 - Lidl Silvercrest FB20-002/HG06323 remote
  description: >
    Control lights with the Lidl Silvercrest remote (FB20-002/HG06323) via
    Zigbee2MQTT 2.x event entities.
    - **On/Off buttons**: Toggle lights on or off.
    - **Brightness Up/Down click**: Step brightness up/down by 10%.
    - **Brightness Up/Down hold**: Smoothly dim until released (`brightness_stop`).
    - Optional override actions for holds.
    - Optional forced brightness when turning on.
    & by MrLemur: https://community.home-assistant.io/t/zigbee2mqtt-lidl-silvercrest-livarno-lux-switch-and-dimming-light-remote-control/260323
  domain: automation
  input:
    remote:
      description: The Z2M event entity of the remote
      selector:
        entity:
          domain: event
    light:
      selector:
          entity:
            domain: light
    force_brightness:
      description: >
      default: false
      selector:
        boolean: {}
    brightness:
      default: 50
      selector:
        number:
          min: 0.0
          max: 100.0
          mode: slider
          step: 1.0
    button_long_max_loop_repeats:
      name: (Optional) Button long press - Maximum loop repeats
      description: >
        Safety limit to prevent endless loops if `brightness_stop` is missed.
      default: 100
      selector:
        number:
          min: 1
          max: 5000
          mode: slider
          step: 1
      name: Run custom action on brightness up hold
      default: []
      selector:
        action: {}
      name: Run custom action on brightness down hold
      default: []
      selector:
        action: {}
mode: restart
variables:
  brightness: !input brightness
  button_long_max_loop_repeats: !input button_long_max_loop_repeats
  - platform: state
  - variables:
      command: "{{ trigger.to_state.attributes.event_type }}"
  - choose:
      - conditions: "{{ command == 'on' }}"
        sequence:
          - choose:
                sequence:
                      transition: 1
            default:
                  transition: 1
      - conditions: "{{ command == 'off' }}"
        sequence:
              transition: 1
      - conditions: "{{ command == 'brightness_step' and trigger.to_state.attributes.direction == 'up' }}"
        sequence:
              transition: 1
      - conditions: "{{ command == 'brightness_step' and trigger.to_state.attributes.direction == 'down' }}"
        sequence:
              transition: 1
      - conditions: "{{ command == 'brightness_move_up' }}"
        sequence:
          - choose:
              - conditions: "{{ alt_brightness_up_hold != [] }}"
                sequence: !input alt_brightness_up_hold
            default:
              - repeat:
                  while: "{{ repeat.index < button_long_max_loop_repeats | int }}"
                  sequence:
                        transition: 1
                    - delay: 1
      - conditions: "{{ command == 'brightness_move_down' }}"
        sequence:
          - choose:
              - conditions: "{{ alt_brightness_down_hold != [] }}"
                sequence: !input alt_brightness_down_hold
            default:
              - repeat:
                  sequence:
                        transition: 1
                    - delay: 1
      - conditions: "{{ command == 'brightness_stop' }}"
        sequence: []
