ZigBee2MQTT list / map - displaying not correctly
I am currently converting to Z2M. In the process, I noticed right at the beginning that something is displayed wrong. Can I correct this (if yes - how?)
I have restarted everything, deleted the coordinator_backup.json, re-registered the socket… same result.
The socket is not recognized as a router
The double switch is not recognized as connected (map).
Coordinator is: TubeZB CC2652P2 based Zigbee to Ethernet/USB Serial Coordinator
But everything works!!!
For the missing links there’s an FAQ entry.
For the device that’s not showing as a router, that’s because the power source is unknown - possibly an interview problem.
Thanks,
Solved
