Blueprint for LoraTap (Tuya) 6-Button Scene Switch (Zigbee2MQTT)
For the 6 button version: https://nl.aliexpress.com/item/1005004988714663.html?spm=a2g0o.order_list.order_list_main.10.258f79d2W3QAbR&gatewayAdapt=glo2nld
3 options per button (short, double, long (5 sec))
blueprint:
name: Zigbee2MQTT - LoraTap (Tuya) 6-Button Scene Switch
description: Automate your LoraTap (Tuya) 6-Button Scene Switch via Zigbee2MQTT.
domain: automation
input:
switch:
name: LoraTap (Tuya) 6-Button Scene Switch
description: LoraTap (Tuya) 6-Button Scene Switch to use
selector:
entity:
integration: mqtt
domain: sensor
button_one_short_press:
name: Single Press - Button 1
description: Action to run on button 1 (upper-left) single press
default: []
selector:
action: {}
button_one_double_press:
name: Double Press - Button 1
description: Action to run on button 1 (upper-left) double press
default: []
selector:
action: {}
button_one_long_press:
name: Long Press - Button 1
description: Action to run on button 1 (upper-left) long press
default: []
selector:
action: {}
button_two_short_press:
name: Single Press - Button 2
description: Action to run on button 2 (upper-right) single press
default: []
selector:
action: {}
button_two_double_press:
name: Double Press - Button 2
description: Action to run on button 2 (upper-right) double press
default: []
selector:
action: {}
button_two_long_press:
name: Long Press - Button 2
description: Action to run on button 2 (upper-right) long press
default: []
selector:
action: {}
button_three_short_press:
name: Single Press - Button 3
description: Action to run on button 3 (middle-left) single press
default: []
selector:
action: {}
button_three_double_press:
name: Double Press - Button 3
description: Action to run on button 3 (middle-left) double press
default: []
selector:
action: {}
button_three_long_press:
name: Long Press - Button 3
description: Action to run on button 3 (middle-left) long press
default: []
selector:
action: {}
button_four_short_press:
name: Single Press - Button 4
description: Action to run on button 4 (middle-right) single press
default: []
selector:
action: {}
button_four_double_press:
name: Double Press - Button 4
description: Action to run on button 4 (middle-right) double press
default: []
selector:
action: {}
button_four_long_press:
name: Long Press - Button 4
description: Action to run on button 4 (middle-right) long press
default: []
selector:
action: {}
button_five_short_press:
name: Single Press - Button 5
description: Action to run on button 5 (lower-left) single press
default: []
selector:
action: {}
button_five_double_press:
name: Double Press - Button 5
description: Action to run on button 5 (lower-left) double press
default: []
selector:
action: {}
button_five_long_press:
name: Long Press - Button 5
description: Action to run on button 5 (lower-left) long press
default: []
selector:
action: {}
button_six_short_press:
name: Single Press - Button 6
description: Action to run on button 6 (lower-right) single press
default: []
selector:
action: {}
button_six_double_press:
name: Double Press - Button 6
description: Action to run on button 6 (lower-right) double press
default: []
selector:
action: {}
button_six_long_press:
name: Long Press - Button 6
description: Action to run on button 6 (lower-right) long press
default: []
selector:
action: {}
source_url: https://github.com/enipos/ha-blueprint/blob/main/blueprints/tuya/loratap_(tuya)_6button_scene_switch_z2m.yaml
mode: restart
max_exceeded: silent
- platform: state
entity_id: !input "switch"
attribute: action
- variables:
command: "{{ trigger.to_state.state }}"
- choose:
- conditions:
- "{{ command == '1_single' }}"
sequence: !input "button_one_short_press"
- conditions:
- "{{ command == '2_single' }}"
sequence: !input "button_two_short_press"
- conditions:
- "{{ command == '3_single' }}"
sequence: !input "button_three_short_press"
- conditions:
- "{{ command == '4_single' }}"
sequence: !input "button_four_short_press"
- conditions:
- "{{ command == '5_single' }}"
sequence: !input "button_five_short_press"
- conditions:
- "{{ command == '6_single' }}"
sequence: !input "button_six_short_press"
- conditions:
- "{{ command == '1_double' }}"
sequence: !input "button_one_double_press"
- conditions:
- "{{ command == '2_double' }}"
sequence: !input "button_two_double_press"
- conditions:
- "{{ command == '3_double' }}"
sequence: !input "button_three_double_press"
- conditions:
- "{{ command == '4_double' }}"
sequence: !input "button_four_double_press"
- conditions:
- "{{ command == '5_double' }}"
sequence: !input "button_five_double_press"
- conditions:
- "{{ command == '6_double' }}"
sequence: !input "button_six_double_press"
- conditions:
- "{{ command == '1_hold' }}"
sequence: !input "button_one_long_press"
- conditions:
- "{{ command == '2_hold' }}"
sequence: !input "button_two_long_press"
- conditions:
- "{{ command == '3_hold' }}"
sequence: !input "button_three_long_press"
- conditions:
- "{{ command == '4_hold' }}"
sequence: !input "button_four_long_press"
- conditions:
- "{{ command == '5_hold' }}"
sequence: !input "button_five_long_press"
- conditions:
- "{{ command == '6_hold' }}"
sequence: !input "button_six_long_press"
