Zigbee2mqtt: Lovelace custom card to show zigbee2mqtt network map
says refreshing but no show also with default theme :frowning:
Then is is not set up properly, because believe me it does work.
iā€™m not saying that it does not work.
problem is that sensors appear on the states but not on the panel, and i checked the configs and everithing shows right but i might miss something.
can you share your config to compare?
anyone that could share the config?
Add via HACS
Add a new lovelace view
  - title: Zigbee Network
    panel: true
    cards:
      - type: custom:zigbee2mqtt-networkmap
        entity: sensor.zigbee2mqtt_networkmap
Sorry plus this in configuration.yaml of course, but I think you have that already.
  - platform: mqtt
    name: Zigbee2mqtt Networkmap
    state_topic: zigbee2mqtt/bridge/networkmap/raw
    value_template: >-
      {{ now().strftime('%Y-%m-%d %H:%M:%S') }}
    json_attributes_topic: zigbee2mqtt/bridge/networkmap/raw
many thanks i had
panel: yes , instead panel: true thanks for the help
