Zigbee2mqtt migration error
I just migrated Home Assistant to a new machine. I moved from an older win10 desktop running Home Assistant on a Virtual Box VM to a new NUC 100 flashing the SSD with HAOS 13.X. Zigbee2mqtt migration was my biggest challenge. Z2M seems ok, but I am not sure. I underlined what I think are 2 errors in line one (1) of the “database.db” file, as seen in the file editor. If I am correct, can I edit out the underlined MAC portion of the coordinator in the “database.db” file with the MAC portion showing up in the add-on config IU and/or the setting > serial as seen in the zigbee2mqtt. And should the coordinator “nwkAddr” be number 1 (one)? No other coordinators is listed in the “database.db” file. And yes, I change out the coordinator during the zigbee2mqtt migration.
In zigbee2mqtt > setting > serial, I see…
/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_181f9a756399ec11aa390bc944d80d13-if00-port0
In zigbee2mqtt addon configuration is see…
port: >-
/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_181f9a756399ec11aa390bc944d80d13-if00-port0”
In file editor /homeassistant/zigbee2mqtt/database.db, the first line begins with…
{“id”:1,“type”:“Coordinator”,“ieeeAddr”:“0x**00124b00257ca3fc**”,“nwkAddr”:0,“manufId”:0,“epList”:[1,2,3,4,5,6,8,10,11,12….
Thank you for any help
