Zigbee2MQTT migration from Sonoff USB to SLZB-06p7
Is it possible, if I change the serial port config in the ZB configuration file and pull out the USB dongle that Z2MQTT will startup with the SLZB network port?
Now I have changed it but in the logging it says something about the same network and panID but I don’t want to pair all devices again if I would delete some files.
