Hello! I’m kinda new to the HA community. I have a problem with my Zigbee switch. I’m using Home Assistant with zigbee2mqtt add-on and CC2531 receiver. I have moes neutral/no neutral switches, 2 and 3 gang version. 3 gang works great without any issue. However, my other 2 gang switches misbehave. Zigbee2mqtt discovered them as TS0012 model. Whenever I switch on/off one of the switches (left or right) the other side activates/deactivates too. When I switch on left side, the right one switches on too after around half a second. When I switch the right side on, the left one switches on too immidiately. I can’t power on or off only one side of the switch. How can I debug the issue?
I have moes switch and I believe it has nothing to to with z2m. Check your wiring first.
If wiring is oke than the only way for this to happen is if you configured it to behave like that.
Wiring is ok. I connected them just like the 3-gang version. Both 2-gang versions behave that strange way exactly after pairing them to the zigbee network. No configuration to them has been made.
Also make sure the lights connected are not some cheap 7 watts LEDs, especially if you have no neutral line going to the switch. If you got capacitors with those switches try to install one between L1 and N close to the LED.
