Zigbee2mqtt moes switch problem
A simple post with the correct info would have been smart
Hi, I tried your fix with external converter in the configuration.yaml for my MOES 2 gand switch but without success. Can you please help me. My problems is: when I switch on ether left or right gang it is working, When I switch on the other one after half a second both are switching off. In other words I can’t turn on both left and right in the same time. The switch is without neutral wire. Zigbee2MQTTis version 2.3.0-1
Thank you in advance
What’s your exact switch model? I haven’t used any external converter since Jan 2023 as the newer zigbee2mqtt versions fixed all my issues.
Can you show the wiring?
[quote=“slvrk, post:66, topic:451248, full:true”]
[/quote]
The installation is without negative wire. On the right is the “line” wire. The middle and the wire on the left are going to the ceiling lamp and kitchen cabinets lights.
Thank you very much for the photo. Is the strange behavior present both on manual click and via zigbee trigger?
My switch is reporting as same model, however it looks different from behind. It seems, probably, they must have changed the logic for it, hence the issue.
The behavior is the same whatever you are pressing physically the buttons on the switch itself or toggle them from the z2m.
Have you tried using it with other solution rather than z2m or manually without paring/after reset?
No, I am trying to use it only with z2m. Erased and pair it a couple of times - the same behavior. I am using it with HA SkyConnect like a coordinator and I am observing issues with other Zigbee devices as well.
I purchased new coordinator - the SM Light SLZB-06. Waiting to be delivered to me. Once I have it I will replace the SkyConnect and will report again.
Oh, with other devices issues as well. Okay then. If it doesn’t help you’ll probably need to debug the switch and create own support for it as the model you have is different from mine (at least the device look from behind).
